Speed Bleeder Install
Old 01-17-2013 | 08:30 AM
casique's Avatar
casique
Default Speed Bleeder Install
When installing the speed bleeders, do you guys open the master cylinder or leave it closed.
I would think open to do away with pressure, but looking for any experience out there. Thanks.
Old 01-17-2013 | 08:44 AM
soos's Avatar
soos
I installed mine during a brake job so my covers were off anyway. It can't hurt, it's only 2 screws.
Old 01-17-2013 | 08:49 AM
Jinks's Avatar
Jinks
Either way. If there's pressure at the caliper with the brake released something is wrong with the system anyway.
Old 01-17-2013 | 11:41 AM
run1fsr's Avatar
run1fsr
I installed mine when open. Just be carefull not to splash fluid when moving the bars / front end.
Old 01-17-2013 | 12:25 PM
casique's Avatar
casique
Just hoping not to suck in any air.
Old 01-17-2013 | 12:45 PM
CSS_FXD's Avatar
CSS_FXD
If you suck air in just bleed it out
Speed bleeders rock! Best thing you can install for your brakes.
Old 01-17-2013 | 01:58 PM
CurtisO's Avatar
CurtisO
Yes, leave the master cylinder open. Be sure to watch it doesn't run out of fluid while you are bleeding. This would be a great time to flush all the old brake fluid out.
Old 01-17-2013 | 02:32 PM
Jinks's Avatar
Jinks
Unavoidable, but that's why you're installing "Speed Bleeders". You won't let much air into the system, & when you flush it with clean brake fluid all the air will be bled out.
Old 01-17-2013 | 04:37 PM
Renold's Avatar
Renold
I did speed bleeders about a year ago. They are great. I pumped the old fluid all the way down and wiped out the reservoir. It was a little rough looking in there. I then filled and pumped until refilled and bled. Takes longer getting tools together than any of it. Fifteen minutes for both reservoirs.
I did have one unusual problem when I did mine. When I removed the FL stock bleeder the threads from the caliper came out with it!! I am not sure why but I had to replace the caliper. I think someone somewhere must of had it cross threaded. It was the first time I had a wrench on it.
Anyway good luck on these.
Old 01-17-2013 | 04:44 PM
Redcrow's Avatar
Redcrow
Can these be used with ABS, or will the dealer still have to bleed brakes?
Quick Reply: Speed Bleeder Install
