Custom Auxiliary Lighting Kit
There are two kits available for the FLHR & FLHX, First being 69227-04A (FLHR) & 69818-06 (FLHX) Anyone know for sure if the 69818-06 will fit a 2006 road king? My bike currently has the FLHX style directionals (on the side of the fork) The past owner must have taken the aux lights off and moved the directions down. Will the kit for the FLHX fit my bike? Then all i would need is the lights and trim rings. Has anyone added the custom FLHX kit to a road king? The wiring I can handle...Thanks for any help....I also have the detachable windshield...
I have not done the swap myself but I can tell you the custom passing lamp brackets are not intended for use with a removable windsheild. Where they mount to the forks, they are just like your current Street Glide turn siginals. If the previous owner figured out how to get the sheid to work with them (or you don't care about the sheild) then they will work fine. You will need to purchase the turn siginal kit also.
Trim rings come with the FLHX kit also.......
I did some looking and I found all you need is the detachable windshield kit Harley part number 69235-04. You may already have this kit if there is a place behind your street guide like turn signals for your sheild to slip in and mount into.
Then all you need is the aux lamp kit and turn siginals and a little time........
NiteOwl
08-17-2010 12:41 PM
