Cam Change inner bearing ??
RE: Cam Change inner bearing ??
If your already in their do it. I had my Stock Cams & bearings replaced at the 1000 mile service with S&S 510G Cams & S&S bearings. 16,000 miles latterI'm now getting ready to swap out the 510G's with a set of HQ-0039G's and I'm going to replace all the bearing with new ones again. Better to be safe then sorry.
I'd have to agree with the others, I just installed Andrews cams with S&S gear drives. Changed out the bearings and you can definitly see that the replacements have larger needle bearings over the stock ones. You will need a bearing puller and installation tool for the inner bearings. There are two different tools, one for outer and one for inner. I did'nt need one for outer but can't see how you could replace inners w/o possibly FUBAR. I bought tool from Zippers.
thewholehog
Exhaust System Topics
11-21-2009 09:18 AM
