Power Vision with a Power Commaner V
Hi everybody, I'm new here so bear with me as I get to know everyone and learn the ropes. Been lurking for a while and have found some good information here (and some great entertainment
) so I thought I would pose a question to those using Dynojet products.
I have a 2012 Road Glide Custom (103) with a Big Sucker, Bassani Road Rage II and a Power Commander V with Autotune. My question is, would it be any benefit to get a Powervision, flash my ECM with my latest tune and then continue to run the Power Commander V with Autotune? Would selling the PC V be the best option after upgrading since the PV can use the same autotune module?
The PC V and Autotune has done a great job of tuning the bike, runs strong without any hiccups or pops and has performed flawlessly in the year I've had it on the bike so I'm very happy with the PC V. I do, however, like some of the features of the Powervision from my reading here and elsewhere but I really like the PCV's ability to constantly re-tune the bike in real time. I ride in all seasons and all altitudes, from sea level to 5-6K feet, and it seems to me that real time autotuning would be a plus given these conditions.
I suppose after flashing the ECM my fuel tables would autotune themselves down to near 0% change but there would still be some real time tuning for different conditions. Is the ECM's ability to take into account varying barometric pressure enough?
Just hoping someone here has tried this and maybe Jamie would chime in with his thoughts. Thanks in advance and glad to be a part of the hdforums community.
![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
Autotune.......that's the route I should have gone but since I have the PCV with Stage 1 it's a far cry from stock. Day and nite difference.
check out the FuelMoto web site, i think they still may have the deal, where you can send them your old tuner, and you get about $150.00 off of the purchase of a PV tuner.
Again, i am not 100% sure they are still running this deal.
http://www.fuelmotousa.com/site/tunein.html
Here is the link for the tuner trade in deal which is going on until the end of January 2013, jump on the deal if you can.
Last edited by mgmmgm; 01-11-2013 at 08:58 AM. Reason: http://www.fuelmotousa.com/site/tunein.html
My bike is also far from stock. Stage 1 air intake, Bub 7 True Duals and S&S 551 Easy Start Cams. The Wide Band O2's with the Autotune module and Power Vision WILL do the trick in getting your tune set. With the Power Vision there is no need for the PCV.
Yes! You can run either "Basic" or "Pro" Autotunes with the new Power Vision. The "Basic" uses your factory narrow band O2 sensors to preform the tune and the "Pro" uses Dynojets Autotune module with Wide Band O2 sensors. You'll achieve a good tune with both, but the Wide Band will get you the best tune. Lots of info on the Fuel Moto and Dynojet websites.
