Shock crazy! 2008 vs 2012 WTF?
Make sure the pressure is correct according to the manual. I'm not sure what year (I suspect it was 2009 when they changed the frame), but they changed the configuration and thus the recommended pressure in the shocks. For example, it used to be that 25 psi was recommended for two up. Now it is 40-50. If you have the shocks set according to the old recommendations, which you may have been used to with the RK, they may not be properly pressurized.
Those air shocks blow... I have the HD adjustable premium and they are much better. A bajillion options for rear shocks available and just as many opinions. One thing we will all agree on though is the stock shocks BLOW!
I have seen it posted here before that when folks went to change the oil weight in the stock rear shocks on newer bikes, that there was not the correct amount of oil in them. Not saying this is the problem but may be worth checking.
I could be completely wrong here, but . . . .
I *think* the FLHTK uses the same shocks as the FLHX; 12" vs 13" for all other touring models, including the RK. I have an '02 RK, and within a mile of riding my FLHX home I knew something was not the same. Many miles later, many air pressure settings, and it's not a lot better, especially if you have a previous touring model to compare it to. Maybe if it's your first bike you don't know any different, or if you're riding to the corner, but all I know is that no matter what I've done it's a somewhat rough ride that I wouldn't want to endure on a 8+ hour day. Love the bike, it's just not very comfortable.
I was about ready to spend some bonus money on some tools . . . . but came to the conclusion yesterday that that money would be better spent on a new set of shocks. So after reading up as much as I can, and with all the varieties and opinions out there, I *think* I'm going to go with some Progressive 944's. Do some research and you'll find lots of posts on this topic, for these specific bikes. Some folks have been picking up some 13" take off's from other bikes, but that will raise the back end. Bottom line is there are lots of options, some lower cost, some higher, but the rough ride seems to be one of the more common issues many people have with these two models.
As you see, not everyone agrees . . . but, I know I'd like to be a little 'fresher' after a long day than what I am now. If you don't like the ride, try air settings, and after that there certainly are some options out there . . . YMMV
