Brake pads
Old 01-07-2013, 07:26 PM
porkchopsd's Avatar
porkchopsd
porkchopsd is offline
Originally Posted by Rickr01
I've always just stuck with the OEM stock brake pads on my bikes and not had any issues. However, on my 2010 Street glide, my brakes are the exception. They squeek. I've done all of the fixes ie chamfered the leading edge, installed quiet brake on the back of the pads lubed the slider pins etc. All work for a short time but not permanently. My buddies does the same thing as do others I've heard. What pads besides HD are others running because of the same issues? Lyndal...organic or sintered? Any suggestions based on personal experience is appreciated. These are ABS brakes. Thanks
Had exactly the same problem when I switched to a polished rotor they started to squeek, right away. I switched to Lyndal organic and the problem stopped, right away.
Old 01-08-2013, 09:32 AM
Rickr01's Avatar
Rickr01
Rickr01 is offline
Thanks much folks! Maybe I'll just pull the pins lube them up again and put on new OEM pads? The dirt road I ride daily may have a bearing on this?
Thanks again guys.
Old 01-08-2013, 09:43 AM
Duke 07's Avatar
Duke 07
Duke 07 is offline
Mine was squeaking for a while. I picked up some break cleaner, (bio-friendly stuff) cant remember the name but wanted something that would not hurt the finish on my rims. After I road a few times and cleaned them after, it finally stopped for the most part. Mine are quite now, it took a few weeks of the treatment, not sure why this worked but it did.
Old 01-08-2013, 11:24 AM
Rickr01's Avatar
Rickr01
Rickr01 is offline
Thanks...I'll try that out first? Worth a shot! Unfortunately, I won't know much until May. Its the earliest I can generally get my bike off of a spring muddy dirt road here in Vermont! Love that Mud Season..LOL
Speed00
09-03-2018 08:55 AM
hAkron
2014-2023 Touring Models
14
08-10-2017 08:02 PM
cencal
05-23-2017 09:33 PM
fltrxcrzy
10-01-2015 01:55 PM
saintdaniel
04-10-2008 04:11 PM
Quick Reply: Brake pads
