Road Glide Mods (cams etc)
Hey I just bought a 2005 Road Glide and want to do some upgrades to it. It has Thunderheader on it but otherwise it is a stock motor. I am thinking of doing the S&S 97 big bore with easy start cams and a high-flow air intake and a Race Tuner. I am hoping that this will get me 100HP and good torque.
Any sugestion on how to get that kind of power out of my bike?
Thanks!!
Thanks!!
I used the S&S 97" kit on a 2005 Road King, and really liked it. I didn't get the kind of HP that you're looking for, but I didn't so any head work. Therein may be the difference. Others will likely be able to help you more than I can, but as I remember right I ended up with low to mid 90's as far as HP went. Can't really rememeber. I did like the results though, with the S&S 97' big bore.
Good luck to you.
Good luck to you.
Call these guys, they'll get you there if you do the big-bore kit, fuel management system, air cleaner, and head work. www.fuelmotousa.com.
I don't think you're going to get to close to 100 hp either. You're going to need more inches, or more cam, or more stroke. I'm running 107 with S&S 585GEZ cams and worked heads and I'm only getting 121h/132t. It's a great ride though. A little wheel lift on roll on acceleration. Good deep exhaust tone etc.
Heres a 100hp FM 98" with Level B headwork, 10:1, and the stock headpipe..
Another 100hp FM 98" again, level b heads, 10:1
jmb79
10-21-2013 08:30 PM
