Do my soft lowers have a Temperature restriction?
Hello everyone.
I have some soft lowers made by Hopnel that I use in the winter. I have had these for 6 years or so and looks like the newer models say no temperature restriction. Does anyone know if mine are restricted? It would be nice to use them in the summer if Im caught in the rain. I know, why ask now after 6 years? It's just been on my mind lately.
Thanks!
Thanks!
Honestly, I don't know what the big deal is. As long as there is a way for air to get to the cylinders, you should be good to go. I know that some say to remove them when the temps get above 50 degrees F. But I have yet to see anyone yanking off the hard lowers from the Ultras during the summer.
50ºF
the soft lowers ( or crash bar covers), do not channel the air, they cause a huge amount of turbulence, drastically reducing air flow to the motor- the voltage regulator and the oil cooler (if equipped). The turbulent air just kinda boils and roils off to the sides.
the air coming off of the front wheel and fender is pretty turbulent as well.
hard lowers "order" air to the motor causing increased air flow. My own testing at 105º ambient temperatures, show the oil temperatures 25º cooler WITH the lowers in place.
however the increased air flow and heat removed from the motor can increase the "blow dryer effect" felt by the rider on the thighs
mike
mike
50ºF
mike
mike
I don't know why I couldn't find these, but just found a link to the ones I have. They don't say anything about temps
http://www.jpcycles.com/product/702-196#
Here is a link to desert dawgs with no temp restriction. I don't see how these pass more air. They look to be the same width.
http://www.leadermotorcycle.com/dese...-street-glide/
Don't know anything about those products, the 1st says "protects from weather" the second says "rain guards".
Both of those suggest temporary use.
and they might have a notice on the box.
harley has deeper pockets to protect and makes model-specific recommendations, so has a good reason to say "below 50ºF"
mike
mike
Soft Lowers
I can only speak from my own personal experience: On my EGC when it started raining while on a trip, I stopped and put on the soft lowers. The rain eventually subsided, the sun came out and the temps started rising. Within minutes the motor started running poorly ( missing) and I immediately pulled over and removed the soft lowers. After doing so, the bike started running just fine!
Lesson learned: When the temps get above 55 degrees, remove the soft lowers!
The H-D hard lowers are designed to funnel the air over the cylinders, whereas the soft lowers tend to destroy the airflow over the cylinders.
on my 05 i would use em up tp 70 without a problem but that bike ran MUCH cooler than my 07,on my 07 i wouldn't use em above 40.just depends on your particular bike,that all run different.harley tolerances aren't all that tight and depending on how far from center and wich way on every engine component u can see huge difference in 2 same year and model.
