Switching Back to the OEM Horn
I bought a 2007 Street Glide last year and it had the Harley Davidson air horn on it. I'm probably in the minority here, but I don't like it and want to put an OEM horn and cowbell cover on.
There is a ton of posts here about taking the OEM horn off and puting a different horn on, but can I use the wiring that is in place for the air horn for the OEM horn? I'd prefer not to remove the tank if it can be avoided. Thanks in advance for any help.
The OEM uses two wires, black and Black w/yellow stripe with sidewise flag terminals, female. If you got those two wires still in tact it should be a plug n play.
You need to check and ensure that the current wiring actually has voltage on it when you press and hold the horn button. That may be why the air horn is now working. If there is no voltage at the horn, then you need to trace it back to the relay. It's a good bet that a spade terminal or two might be loose or separated. But if there is voltage getting to the air horn, then the OEM will work fine with those same supply wires.
LOL! I kinda have the same problem only its my fault. I bought that damn Harley Air Horn and paid WAY TO MUCH for the piece of crap. Harley doesnt even sell it anymore and just about any reference to it in the Dealer Parts database has been purged! Fortunately my Extended Warranty reimbursed me for what I paid for it after replacing three of them. The last one, not working, is still mounted on my StreetGlide and I want to do the same thing. Reverse engineer this piece of plastic chrome crap OFF the bike and put the OEM horn back on.
