Question About 103 Cylinders/Pistons
Old 01-02-2013, 10:31 AM
1sweetglide08's Avatar
1sweetglide08
1sweetglide08 is offline
Default Question About 103 Cylinders/Pistons
I brought a used set of low mileage 103 cylinders and pistons. When they arrived the pistons were in the cylinders. This may be a dumb question but how do you get the piston out of the cylinder? I thought the piston would just come out. I want to send the cylinders to FuelMoto for a FM 107 without the pistons. Thanks for any advise.
Old 01-02-2013, 10:34 AM
CHIPPDOG77's Avatar
CHIPPDOG77
CHIPPDOG77 is offline
Hammer handle.
Old 01-02-2013, 10:38 AM
av ultra's Avatar
av ultra
av ultra is offline
Like posted, with a hammer handle gently from the top of the piston down, you should be prepaired to catch the piston, it should come out really easy.
Old 01-02-2013, 10:44 AM
1sweetglide08
Thanks...I thought it would be a simple answer.
Old 01-02-2013, 10:48 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,847 Likes on 1,085 Posts
Just be sure that you don't use a metric hammer.
Old 01-02-2013, 10:58 AM
1sweetglide08
Lol...oh yeah I forgot about that.
Old 01-02-2013, 11:15 AM
2009blackpearle's Avatar
2009blackpearle
2009blackpearle is offline
Default hope they airnt rusted in
hope rings didnt rust to the cylinders your gonna be boring them out anyway it probably wont matter, but if you were staying with 103 you may have a problem
Old 01-02-2013, 12:00 PM
Fast Aire's Avatar
Fast Aire
Fast Aire is offline
Former Sponsor
Turn the cylinders upside down, spray some WD40 around the piston/cylinder contact area, flip them over, spray some at the top, let them soak a little & tap out with a hammer handle.
Old 01-02-2013, 04:00 PM
1sweetglide08
Just as most said... I tapped them out with the end of a wooden hammer handle.
Old 01-02-2013, 05:37 PM
jfarrar30's Avatar
jfarrar30
jfarrar30 is offline
Sorry bout that Bruce. I didn't think u wanted the pistons but I stuck then in there just in case for you.
Quick Reply: Question About 103 Cylinders/Pistons
