connections of Lights, AKA MOlex
I have a small paper clip that I use. I clipped one end on a steep angle with some wire cutters, and filed it to a nice point. It slides right under the tabs to release the pins.
Sometimes, it helps to push the pin further in, to relieve pressure on the tabs, and then slip the paper clip under. Also, sometimes a second set of hands to pull the wire helps.
[QUOTE=Bushy;10727024]Have to ask... what is the best tool besides the actual tool to remove safely they Connections for the wires into the housing.... IE: Tooth pick,mall screw driver,,,, Prayer[/QUOTE
http://www.walgreens.com/store/c/walgreens-deluxe-eyeglass-repair-kit/ID=prod352661-product?ext=gooPersonal_Care_PLA_Eye_Glass_Cleaner s_ampersand_Accessories_prod352661_pla&adtype={adt ype}&Kpid=prod352661&sst=6a771b8c-e34e-aea9-ca76-0000510bf556
...or a small jeweler's screwdriver.
