on my toes...
what you need is a narrower seat I modified my stock seat just to get by while I figured things out I simply cut some foam off sides and re stapled it. In the end I lowered front about 1 inch and I like the mustang day tripper seat and I have modified a second mustang seat with back rest for travel.
I do not recommend the reduced reach seat I tried it did not like it. The worst seat I have ever tried had to beg them to take it back. The short story look at front end lowering just bring front down to level look into seat options boots are nice but you do not need platform boots LoL. and by the way I am 5-4 1/2
Definately do the Progressive lowering kit, that will help a ton, taller boots as mentioned, and check out Mean City Cycles seat tweaks before you buy a new seat, much cheaper to try first. They have several options you can choose from if your on the shorter side or bigger side, some lower the rider up to 3".
**NEW** Super Narrow - $135
(Note: For stock Harley Davidson Touring bike seats 2011-2012)
We reshape the sitting area of the seat to lower the ride height as much as possible and change the foam to Memory foam in the driver's sitting area. We narrow the seat pan where your legs go down so that the seat doesn't keep your legs spread apart as much and this really helps get your feet on the ground a lot better. (With this modification we can lower the riding position or keep it stock height. We can move the riding position forward or back or maintain the current front to back sitting position.)
- Note: For stock Harley Davidson Touring bike seats 2011-2012
1 Post
Hello from Redcar England.
Ride like the wind and never stop to put your feet down lol.
There are lots of riders that are not tall, I think people just manage as they get used to a bike. Seat sounds a good idea but if you drop the back end things will catch sooner its a trade off. Should be ok either way.
Good luck with the bike.
tbone
tbone
I'd try the Progressive lowering kit first. May as well do the Monotubes with a 1" to 2" drop.
If that don't do it, I'd try some 11" shocks from Progressive. The seat would be the LAST thing I'd change. I had MCC do my seat twice and it is still less comfortable than it was when I took it in the first time. The HD Reach seat is really uncomfortable for any distance and it pushes you up on the tank where your knees are damn near hitting the bars. The Corbin seat may be an option since they are lower and can be narrower.
But.....I'm 5'6 and have Ohlins 3-3's on the back. I'm tippy toeing when solo, but when the wife gets on I can flat foot in riding boots.
When tire time comes, I'm gonna look for some lower profile tires.
More spread the better. My short friend has dropped his Roadking 3 times till he just gave up and got a Softail since he could in his mind get it lower. Not sure about that. I am 6'3" and been thankful many times. I know I would have been on the ground many a time since once it gets over too far your leg spread offers more leverage then just strength alone can do.
