07 SG Throttle out of control
Old 12-30-2012 | 10:24 PM
nitrorc's Avatar
nitrorc
Default 07 SG Throttle out of control
Rode bike today was riding fine, then all of sudden throttle was not responding correctly. Pulled over off FWY looked over bike and noticed throttle stop screw was turned all the way UP, causing bike to rev over 4K rpm. Turned it backed down with finger from the back side of air cleaner and back to normal. Has anyone experience this screw moving by itself? Do I need to be concerned with this? I was going to loctite this in place.
07 SG with V&H true duals, stage I, and Power commander. Should I take this into dealer?
Old 12-30-2012 | 10:35 PM
Lonewolf176's Avatar
Lonewolf176
Fairly common problem. If you can data log it you need to set it close to 40 iac steps at 105* C. Use red locktite. Make sure it still shows 0% tp and .57 volts. You will need a 5 pt torx. Snap on
# is TTXR15TPE.
Old 12-30-2012 | 11:02 PM
nitrorc's Avatar
nitrorc
So what if I don't have all the high tech equipment to set the TP and volts. Can I set it 1K rpm and locktite it there? How can I accomplish this without all the tools?
Old 12-30-2012 | 11:42 PM
Lonewolf176
I would think it's pretty difficult, but maybe worth a try. All you need is someone with a tuning device that will data log. Even though you can't program your bike with someone eles's device, you can data log.
Old 12-30-2012 | 11:43 PM
Scorpion07's Avatar
Scorpion07
I have a feeling you're dealing with this https://www.hdforums.com/forum/touri...le-issues.html
Kinda inconclusive, but the problem is generally on the 07's only.
Old 12-31-2012 | 12:54 AM
Fast Aire's Avatar
Fast Aire
Former Sponsor
Had the same thing happen to a friends 07 RG this past summer. Got it back to my house, unscrewed the stop screw, put red loctite on it, set the tach to right below 1000 and it was good to go. It was a mechanical malfunction not electrical so it got a mechanical fix. It ran perfectly all they way thru Fall when he traded it for a 13.
Old 12-31-2012 | 10:14 AM
Lonewolf176
Sure that will get you close. There will be a fairly broad area of adjustment where the bike will idle at 1000 rpm. Air flow through the tb at idle is controlled by the throttle blade opening and the iac motor. Setting the throttle blade to see the correct amont of iac steps just makes sure the iac has the range to adjust. Very easy to adjust it correctly.
nitrorc
02-16-2013 06:53 PM
north texas harley
06-15-2012 10:24 AM
ICIBUY
08-24-2009 09:54 PM
fraz00
11-19-2007 10:34 AM
cantdecide
09-28-2006 05:00 PM
Quick Reply: 07 SG Throttle out of control
