Tensioners
In 2007 HD upgraded/changed the cam tensioner design from spring loaded to hydraulic. The 07+ tensioners are far less trouble than the pre 07 spring loaded ones were.
The only way to check them is to remove the outer cam cover and inspect them.
My 07 SG has 31+ K miles & no issues. There are other here with far more miles & no issues.
I found my cam tensioners were wore past the wear limit at 30 k mi or so. It wasn't making any strange noises but when I installed the new cams I found I needed to replace the tensioners. There are limit marks in the plastic and mine were wore past the marks and almost to the metal pivot pin.
My cousin just had his go bad, said it had a metal on metal sound that was not always there. Said it sounded like a chain making a dinging sound from time to time.
Hi from the UK and welcome to HDF. Your friend's friend is well meaning but not exactly right! The cam tensioner problem was with TC88s and your bike is an early TC96, which has an upgraded system. So from what I can make out you don't need to change them. Others will be along soon and add to that!
