95 inch build
Old 02-04-2007 | 05:39 AM
rideon's Avatar
rideon
Default 95 inch build
Just got my bike back from the builders and I'am extremely happy with my results.
10.0 comp, TW6HG gear drive cams
performance seat grind, valve springs
rinehart true duals
PC tuned
Max power= 101.10 Max torque= 105.23
Gotta say holy crap those rineharts are flippin loud now! I never saw a bike being tuned on a dyno before and was really cool. The bike seems to run really well with a real nice lope to the idle with mucho base from the rineys. I had compression releases installed but it seems to start easily without them. Hats off to Jarz Performance in Abbotsford B.C. for a job welldone. If only it would quit raining[:@]
Old 02-04-2007 | 06:52 AM
apachethunder03's Avatar
apachethunder03
Default RE: 95 inch build
Congats on your build. I just had the cams installed. Couldn't afford the pistons & cylinders.Hoping next year.
Old 02-04-2007 | 12:26 PM
maineultraclassic's Avatar
maineultraclassic
ORIGINAL: rideon
That is why I had to get rid of them..........couldn't ride without getting a throbbing headache. So I went to a 2-1 to get even more power and better performance.......and it's fairly quiet.
Steve
Old 02-04-2007 | 12:29 PM
Abnmarine's Avatar
Abnmarine
Congrats on the build. Very impressive results. What rpm does you bike break 100 tq?
Old 02-04-2007 | 01:20 PM
Bruce00's Avatar
Bruce00
damn nice numbers! Could you post the dyno sheet for comparision
Old 02-04-2007 | 02:39 PM
rideon's Avatar
rideon
At about 3200 rpm it breaks 100 torque, I could lower the rpm considerably if I went with 2 into one but what the hell its still got plenty of power! I will try to get the GF to post the dyno sheet for me, I'am a little computer challenged
Old 02-04-2007 | 02:47 PM
Fandango6's Avatar
Fandango6
ORIGINAL: rideon
rinehart true duals
PC tuned
From my undestanding, if you get the quit baffles for your Rienherts you will not only be quiter, but should increase torque.
Old 02-04-2007 | 02:48 PM
bountyhunter's Avatar
bountyhunter
Hey, another mythbuster build showing TRUE DUALS make comparable power to those "other systems"....nice job!
Old 02-04-2007 | 02:55 PM
04RoadKing's Avatar
04RoadKing
ORIGINAL: bountyhunter
Come dude we talked about this before. Remember it's peak power....... Not low end TQ & HP....
Old 02-04-2007 | 03:02 PM
wldbill's Avatar
wldbill
I'm still living the myth that 2into1 is better than TDuals. But, I'll venture a guess that if you get the front and rear cyls dyno-tuned right, the exhaust setup will matter less. The baffle setup was part of the dyno tune adjustment, so I'd check around before playing with the baffles. Just a thought, I'm no expert.
