Not happy with 31 tooth pulley install!!!
Old 12-27-2012 | 01:18 PM
Brick0044's Avatar
Brick0044
I dropped to a 30T and used a Gates PC-139-1. I believe it is 1 tooth shorter in length.
Old 12-27-2012 | 01:24 PM
nvsteve's Avatar
nvsteve
Originally Posted by MichiganRider
My bike is a 2011. I already have the 68 rear right?
Correct.
Old 12-27-2012 | 01:47 PM
Rhonda's Avatar
Rhonda
Barstock between cam and bump on swingarm is what I used. I tacked it at top and bottom with my mig welder and painted it. I used the 30t triglide pulley and kept my stock belt. I used an air end-grinder to elongate the slot in the swingarm about 1/4'' so I could keep the stock belt. I saved money and felt like this is important if traveling and break a belt. Total cost was less than a hundred bucks. I love the way it's geared now. This is the best mod for the money that I have done. Hope this helps. Allyn
Old 12-27-2012 | 02:31 PM
MichiganRider's Avatar
MichiganRider
32 tooth pulley= 140 belt
30 tooth pulley= 139 belt
31 tooth pulley= Something in between??? lol
I'm thinking harder about modifying the cam adjusters. I only need maybe a 1/8" or so. Have to check if I have room in the swingarm for the axle to slide back a little more.
Old 12-27-2012 | 02:40 PM
scooter_trash_1's Avatar
scooter_trash_1
Talking 31 Tooth sprocket
Either way, block or modify the cams, you are going to have to remove some in the back of the swingarm slots, a barrel cutter on a diegrinder will do this nicely..I did the cam modification, worked fine for me, although either would accomplish the same thing..my thought was that if I decide to go 30 tooth, I could put the blocks in and still use the same belt, replacement on the road reason..stock is easier to find..Scooter
Old 12-27-2012 | 03:01 PM
Tee Bagger's Avatar
Tee Bagger
fwiw....i did the 30t andrews front sprocket and chain... very happy with the results...and the bonus was no more banging compensator!!! hells yeah!!!
Old 12-27-2012 | 04:14 PM
bagman1's Avatar
bagman1
On my 07 I used the HD International belt, it fits perfect!
Old 12-27-2012 | 04:38 PM
sporacer's Avatar
sporacer
You need a 139 tooth belt. If you did your research on this site the info is here.
Old 12-27-2012 | 04:59 PM
harley#1's Avatar
harley#1
dropped 1 tooth on my tranny sprocket. did the same as rhonda and blackjeep. cut the stock from a drill bit about 2 sizes thicker than the cam, cleaned to bare metal then exposy the piece on, then a little paint, never know its there and the bit was big enough that i didn't have to grind the axle slot bigger, still got some adjustment.
Old 12-27-2012 | 05:41 PM
dickey's Avatar
dickey
Was thinking of goin' to a 31 'cause my '07 RKC is geared too high stock. Will I have the same issue, or is the old style frame different?
Quick Reply: Not happy with 31 tooth pulley install!!!
