solving 5th gear slip?
To start off, I have searched the many solutions for taking care of the 5th gear clutch slipping on the 6 speed late model transmissions.
The best explaination I have found talks about axial thrust problems.
It appears Baker Drivelines knows about the issue and has a remedy - - -
http://bakerdrivetrain.com/street-door
If anyone has the new door and wants to give some feedback, Please Do.
If your bike is "slipping in 5th gear you got clutch problems, now if it's jumping out of gear then you got other problems, Ive never herd of late model bikes slipping in 5th, as a matter of fact my stock clutch held up just fine with a 107 kit, I put the se clutch spring in just to be safe.
as above, if your clutch is slipping there could be a number of reasons from fluid choice, to clutch material, to wear to adjustment...to spring pressure.
a bad clutch doesn't get better on it's own.
my stock clutch ( 09) works fine on my stage 1 bike...if I had more power, I'd look for a heavier spring....my fxr is hipo and runs a heavier spring as well as kevlar discs
mechanical advantage can also be a factor--- lugging the motor will create problems.
if rpm choice and power are not real issues, then pull the clutch and rebuild with new steels ( or check for warping or burning), new discs and a SE or other heavier spring.
use a standard kind of fluid- "magic" fluids may not work any better than stock- and sometimes not as well over the long run
mike
mike
As av ultra siad, there are many bikes out there w/ over 100+ HP and using the stock clutch set up. My 103 makes 112TQ and it has the original 96" clutch & spring w/ 32K miles on it & it still works fine. Check your disks & plates & if they look good then Id put in a SE spring in before spending a bunch of money. Energy One clutches makes an extra plate kit that Ive read good stuff about.
Replace the least expensive parts first...
Never had this problem and have never read about this problem. (but there are lots of things I have never heard of so go figure) OP does not say he has it either. Apparently Baker designed this for ultra-performance motors...an extremely small percentage of the motors in existence today. So no doubt a very small market.
My best guess is a weak diaphram spring and the helical cut 5th gear is allowing mine to slip and lately it is quite severe.
I am gentle with clutch usage and never had a problem on any other bike believe there is a real problem. Granted the cams,PC-V , air and exhaust mods bump torque and HP.
I would love to know if anyone knows exactly why,what,how and what the sure fix is.
Placed the bike on the lift and will start tearing into it soon, 15k miles 99% two up riding.
I plan to replace both tires with American elites also. Probably have 2-4k left on tread and no significant cupping but some cracking.
