1000 mile service question for DIY'ers ...
Guys, bought the service manual for my 06 SG. Have decided to do my own service. Last new bike service was only 1 hr at the dealer so I know it didnt ALL get done by the book, plus I got a nice chip in my fender. So, on this bike, going to try it myself. May take all day, but the satisfaction will be worth it. After looking through the manual, got a few general questions..
Materials to buy in advance: 4 qts of oil (changing to Mobil 1 Vtwin 20/50 I think)
HD Chrome oil filter
o-ring for drain plug(cheap insurance)
32oz(1 qt) of Formula+ for the primary
oring for drain plug
derby cover gasket
inspection cover gasket
20-24oz of Mobil 1 75/90 syn gear oil for trans
Does this sound good so far? Wondering about the steering head grease and cable lube.. Harley stuff or? Does people and the dealer ACTUALLY ltake apart and lube the cables?What about going through the clutch adjustment proceedure? Do they do it per book or just check cable adjustment and go on?
Lastly, tools.. Looks like I will need to buy a filter wrench, a T25 and T27 torx socket, and a torque wrench. Is there a 1 wrench will do all or do I need both a smaller in/lbs one and a bigger ft/lbs one? Just do the may and use one maybe? What about a belt gauge? Another way to measure?
Time to get to know the bike better I guess. What kind of check list does people use? Make a copy of the book?
thanks alot for any insight or advice before I get going..
derby cover gasket
1 Post
RE: 1000 mile service question for DIY'ers ...
This is the tool for the belt tension :
http://cgi.ebay.com/Harley-Davidson-...QQcmdZViewItem
Take your time you will be fine and know its done right . As far as the torque wrench I have both inch and foot lbs. but you can get foot lbs wrench that starts and very low amount and do the conversion.
ORIGINAL: jrudicel
So, bounty...Explain! lol Do you mean you should remove both the front AND rear axles and lube them? Thanks for everyones input as well. I appreciate it!
this is the most critical service for your bike...I would let a professional tech do it...if you miss something and have a problem later on you may have a warranty issue...it's your coin...penny wise...pound foolish?
Wisdom came from Shovelhead Bob!
Ask this question on the tech forum.
Stay safe.
Stay safe.
Heres the service check-up list done at 1000 miles....
https://www.harley-davidson.com/EX/M...bmLocale=en_US
