Wood TW-888 cam on '12 glide
Old 12-23-2012 | 11:50 AM
Bruce00's Avatar
Bruce00
Originally Posted by Andobone
I have no reason to BS anyone.
Here's a pic of my dyno sheet.
I wasn't questioning your honor or integrity
Those numbers on stock heads has never been done
hence my bs statement
As you probably know, dyno operators can manipulate the numbers
regardless, Iam sure your bike runs great.........and in the end, that's all that maters
Old 12-23-2012 | 12:38 PM
0ldhippie's Avatar
0ldhippie
At any rate that's a nice power curve and I'm sure a great improvement over stock. I put very little stock in random dyno numbers because of all the variables of dynos and operators. Only means something if its before and after or with the same dyno and operator. Take the same bike to five different dynos/operators and ya will get a wide range of results.
Old 12-23-2012 | 04:29 PM
bklynbob's Avatar
bklynbob
very nice curve,ya got the run in SAE also?i
Old 12-23-2012 | 08:53 PM
Teardrop's Avatar
Teardrop
Looks like its gonna be a fun ride Enjoy
Old 12-29-2012 | 03:41 AM
Andobone's Avatar
Andobone
6th Gear
Don't have the run in SAE...but my STD run was done at a 70 degree ambient air temp instead of the usual 60. Without taking that into consideration and given the standard SAE correction factor, that still equates to 101hp. Come on Spring!!
Old 04-04-2013 | 05:52 PM
shady179's Avatar
shady179
Stage III
I have the same cams in my bike all stock 103 and pulled 96 hp and 111 tq but runs like **** down low at idol. It has a hell of a power band down low but those cams need compression and head work. Or they will stumble at low idol till warm. They also have a lot of valve train noise.
Old 04-04-2013 | 05:53 PM
shady179's Avatar
shady179
Stage III
Have stock bike with cams d&d fat cat with stage one.
Old 08-09-2013 | 10:58 PM
okcjetmech's Avatar
okcjetmech
Hummmm
Old 08-10-2013 | 11:21 AM
$tonecold's Avatar
$tonecold
regardless, Iam sure your bike runs great.........and in the end, that's all that umaters
If you go on www.fuelmotousa.com and go to 107 kits you will see that for a long time now they have been showing dyno sheets where bikes with stock heads are producing numbers close to or above 120 ft/lb of torque. I'm not saying they are accurate, but there are dyno sheets and the customers are happy! Here is one of a 107 ci with TW-555 cams and stock heads. I'm really considering trying the TW-888's in my 107.
357sig (03-24-2020)
Old 01-11-2015 | 04:41 PM
timk1230's Avatar
timk1230
Stage I
12 streetglide, 888 cams and lifters, SE pushrods ported heads S &S 58 mm throttle body, 5.3 injectors TTS tuner 110 hp. 115 ft lbs tq
Quick Reply: Wood TW-888 cam on '12 glide
