Well my 80 dollar oil change....
Old 02-04-2007, 01:03 PM
twsteddyna's Avatar
twsteddyna
twsteddyna is offline
Default RE: Well my 80 dollar oil change....
[quote]ORIGINAL: Lil Truckr
I think this was just an excuse to buy more chrome for his scoot.
You can never have enough chrome...Mmmmm chrome[sm=yikesomg.gif]
Shhhh dont tell my wife [8D]
  #32
Old 02-04-2007, 02:33 PM
johnny canuck's Avatar
johnny canuck
johnny canuck is offline
this is scarier than the whinning,clattering,glowing pipes and over heating issues!
  #33
Old 02-04-2007, 10:58 PM
night rider's Avatar
night rider
night rider is offline
First the bolts vibrated loose and fell off. Engineers found out about loctite. Each assembler gets a quart tube. Now the bolts don't get lost and are a little harder to get out. The easy out people are happy, the dealers are happy, ( no one else can get them apart )and it is easier for the salesperson to justify the first $350. oil change.
I was all reved up about buying a new electraglide. Thinking it over I'm going to look at the rest of the field taking into account quality and engineering. The first person that mentions MSRP, no deviations, will not be getting my green.
  #34
Old 02-05-2007, 01:04 AM
waltr's Avatar
waltr
waltr is offline
I don't know abour Aerokroil but Liquid Wrenchworks great also-I ran into some diffficult bolst reoming the cam cover while installing a cam on my '07 and lossened them best possible and sprayed and waited overnight. Worked great.
  #35
Old 02-05-2007, 01:19 AM
Retired_Ted's Avatar
Retired_Ted
Retired_Ted is offline
If they are using red loctite - you must use some heat to break the fastener free - a small propane torch works well.
  #36
Old 02-05-2007, 09:50 AM
Sleeps In Trees's Avatar
Sleeps In Trees
Sleeps In Trees is offline
ORIGINAL: soos
ORIGINAL: Sleeps In Trees
I went ahead & installed an HB-125 & a VPC while I had the cover off.
VicW.
What are these?
The HB-125 is an 'auto-tensioner' for the primary chain & the VPC = Variable Pressure Clutch. - Good stuff! soos, I PM'ed you w/more info.
VicW.
  #37
Old 02-05-2007, 11:49 AM
stglideblk's Avatar
stglideblk
stglideblk is offline
i usually fill mine through the chain adjuster cover, save on a gasket also, and you need to check chain anyway
  #38
Old 02-05-2007, 12:34 PM
glideridemike's Avatar
glideridemike
glideridemike is offline
ORIGINAL: kruzin
What you need to use to break them loose is an impact driver. I learned this 25 years ago. For those who do not know what this is, it's a driver with a 3/8 drive square to put you driver bit on. Fit it to the fastener and hit it with a hammer. Breaks them loose every time.
Just what I was thinking!
  #39
Old 02-05-2007, 12:38 PM
glideridemike
ORIGINAL: waltr
If you can find any, try 'Drip L Do'. I think its made by Castrol. Truly, 1 drop is enough. When you take things apart after you put a drop on you'll find that it runs up the threads all the way, or through corrosion. Unreal. Aerokroil, or Kroil as we call it is maybe the nest best. Then PB Blaster. Last but not least, heat, made by torch.
  #40
Old 02-05-2007, 01:17 PM
fairplay's Avatar
fairplay
fairplay is offline
Hey Ted,
how does the propane torch work out on the chrome?
I've used that method just about everywhere else. just not on chrome
cprhed
07-31-2019 10:07 PM
hAkron
01-02-2019 12:24 AM
whylee
04-03-2015 08:34 AM
Pastor John
09-01-2010 09:26 AM
Pastor John
09-01-2010 07:55 AM
Quick Reply: Well my 80 dollar oil change....
