Any real differences in after market ACs?
Just picked up the 2012 Ultra Limited a few weeks ago and want to keep the stock look to the AC (except for the Live to Ride medallion from forum member zeus33). Maybe I haven't looked enough yet but I can't find any ACs that match the shape including DK Custom and Big Sucker. What am I missing?
However, the DK Naked Pro Billet is made to use your stock cover.
__________________
TRICK!?!? From Harley- See Here
OR
TREAT from DK Custom Products ~ 10% Flash Savings on All Air Cleaners, use Code: Clean10
DKCustomProducts.com
OR
Like everyone said, they all work about the same. All of them drip blowby oil onto the engine. I have read the heavy breather from HD is the only one that does a better job in this regard. No experience with it personally. If there is a better one out there, please let the OP (and me) know.
There's basically two types of high flow intakes. One with a completely exposed filter, the other uses the stock cover or some sort of "bowl" to cover the filter. The completely exposed filter will flow a little more air than the other. The downside is, that halfway thru the season you will be picking bugs, gravel and other **** out of it. On my previous ride, I ran an open filter for a number of years, but cleaning it got tiring, so I switched to an S&S teardrop type. Needed to drop the main jet by half a size and take out one washer from the needle to get it to run the same as the open configuration.
Its your choice. With the EFI and different maps available, either one is going to perform much better than stock. Good luck with it.
...................martin
The biggest diff is a viable solution to the blowby drip not being channeled appropriately to the throttle body.....many along with myself have fashioned a tubing routing that works very well. If I were you I would find one that makes rerouting copper tubing for the BB simpler cuz you will be addressing it whether you want to or not. Do a search on oil drips from AC threads to get a point of reff....otherwise, they all breath the same once you get it out of the restricted backplate.
I ran a K&N filter behind the standard Harley ham-can on my last bike (plastic air box gone). Without some form of forced air induction its hard to make more filtered air available to the motor. The rest, IMO, is eyeball candy. I chose to stay with the ham-can. But there are a lot of sweet looking covers out there. Find one you like and go for it!
