Making clutch pull easier.
Old 12-19-2012, 07:39 PM
rodnock's Avatar
rodnock
rodnock is offline
Default Making clutch pull easier.
Due to Arthritis I am beginning to feel some discomfort in my clutch hAND when riding in city traffic and having to change gears a lot. What can I do to make the clutch pull easier? It doesn't seem to pull any harder than normal.
Bike is a 97 FLHTC.
Old 12-19-2012, 07:44 PM
okcjetmech's Avatar
okcjetmech
okcjetmech is offline
Rbs68cgr's Avatar
Rbs68cgr
Rbs68cgr is offline
Really? I just answered a question like this 10 minutes ago. Lol, but Jp cycles sells a ergonomic clutch. It attaches by lever & reduces the amount of leverage needed to pull clutch. I've never used it but was thinking about it when I broke my hand.
Old 12-19-2012, 08:03 PM
Cliff-AZ's Avatar
Cliff-AZ
Cliff-AZ is offline
I installed a different cam inside the tranny cover where the clutch cable goes in on my 2000 Fat Boy when I did sainless cables. It made the clutch MUCH easier. Like "Butter"
I will look into it and try to find something online for you. I think its what you want.
Only drawback is you need the header off to remove the trans cover if I remember correctly.
Old 12-19-2012, 08:18 PM
rodnock's Avatar
rodnock
rodnock is offline
Originally Posted by okcjetmech
Thanks OKC!
Old 12-19-2012, 08:24 PM
Pelonz's Avatar
Pelonz
Pelonz is offline
I have one of the AIM units and my clutch is so easy it feels like the cable is broken.
http://www.aim-tamachi.com/home.php
Old 12-19-2012, 09:26 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
White Brothers ( rip) originated the Easy Boy Lite Clutch kit- a quick easy install. to save your tranny fluid roll the tires up on a 2x4 and lean on the jiffy ( after removing the exhaust and loosening the trap door bolts).
Also marketed by "Burly" and usually about $26
HD now offers a similar device as stock.
this does affect the operating range of the lever, so proper adjustment of teh clutch and cable is more important.
mike
Old 12-19-2012, 09:47 PM
U-234's Avatar
U-234
U-234 is offline
I pull an easy pull (like the one at BKRider) on my RK that has the stouter clutch because of the 103 kit. I did a little grinding on the hook and it works great. You shouldn't need to grind. I have bought several items from BKRider and have had no problems.
Old 12-19-2012, 09:54 PM
hittman's Avatar
hittman
hittman is offline
+1. Works very well.
Old 12-20-2012, 04:53 AM
blackjeep's Avatar
blackjeep
blackjeep is offline
Lube cable. Surprising difference!!!
Quick Reply: Making clutch pull easier.
