What's the right attenuation for ear plugs
I have researched the forum and haven't found a good answer to how much attenuation to have in my custom ear plugs. I have read that the ones musicians use are good for motorcyclist and they can be 9,15 or 25 db. I don't know which to get. There have to be many guys on this forum that use them and I would appreciate any input.
It is difficult to determine what your needs are, and also the accuity of your hearing ( many of us have hearing loss from age, occupation or both).
the better approach is to try various types of cheapo foam plugs and see what works for you.
from there, if you wish you can have an audiologist make molds of your ear canal and get custom fit plugs
self fit plug lits are also available from guitar center or some gun shops.
myself i find 25dB too much, and 15 not enough.
for the most part, i wear pro-quality earbuds which keep the music in and the noise out- I have a earphone jack wired into my stereo
mike
mike
Your going to make yourself nuts getting the correct protection if your still wanting music to be heard, you may have to choose which is more important. I would follow the earbud advice.....good luck.
the problem is human hearing is rated at 10 hz to 20 K hz. Music obviously falls into this bandwidth.
You could also go after specific frequency attenuation along with decibal level, as I suspect Mike would elude to. If you are serious enough about it you could spend alot of $$$$ and get set up just exactly the way you want to. Filter specific frequencies at stronger levels (higher DB) than others.
