red shift 575 cams
Old 12-06-2012 | 08:57 AM
joee's Avatar
joee
Default red shift 575 cams
has enyone used thr red shift 575 cams in a 103 touring bike
would like to know what it would work like
thanks
Old 12-06-2012 | 11:20 AM
Biker John's Avatar
Biker John
Quick post here? I'm looking into these also...here's a post I found.
https://www.hdforums.com/forum/touri...hundermax.html
I want to bump things up also...but at the same time not open another engine mod can of worms.
---------------------------- Updated below:---------------------------------
Seems as though even they 'Zippers' say they 'Recommend" changing or upgrading push rods...stiffer, lifters, cam chest tensioners even for the basic 525 cams? I'm corned fused but that's normal.
I also found this to add to the edit of this post...http://www.zippersperformance.com/red-shift-525-cams.html
Last edited by Biker John; 12-08-2012 at 09:08 AM. Reason: Updated: Zippers 525 cams...
Old 12-06-2012 | 11:40 AM
mgmmgm's Avatar
mgmmgm
I had these cams in my 07 FLSTF, when I had a 103 build done on it.
I had 9.8:1 comp ( needed comp releases but did not do it ).
The gearing in 07 was taller I think than what FLH bikes have presently, I found I was shifting
More than the guys I rode with, they have fLH's.
The cam seemed to be more of a mid range cam. I did not think my tune was spot on, but mid and upper rpm, it did pretty well. Made 91 hp and 100 torque.
Redshift did just come out with a 525 cam, which looks pretty good and is designed for touring bikes and torque, much like the TW 222 cam.
Old 12-06-2012 | 08:43 PM
dawg's Avatar
dawg
I run them in my 96. Will eventually bump it to 103. Zippers suggest reverse dome (dished) pistons for a 103 with that cam.
Old 12-07-2012 | 06:49 PM
79289Chase's Avatar
79289Chase
I run them in my 106" and do get some pinging pretty easy and it for dang sure needs compression releases in the 106". It does run like hell though. Not sure of power level but it will run off from a stock 103 that's for sure. I haven't ever rode a stock 96 or 103 so I can not say how they do when riding 2up but I did find running from 2800 up is where my bike seems to do best when riding 2 up. Much below that and it doesn't want to pull well and starts pinging if I give it much throttle. It also pulls like hell all the way to the rev limiter at 6200.
Old 12-07-2012 | 07:41 PM
CigarCritic's Avatar
CigarCritic
Better options out there for a stock 103 without head work. For example, Wood 222 cams. The 575's need head work and higher compression.
Click here
Old 12-07-2012 | 09:20 PM
79289Chase's Avatar
79289Chase
I thought Zippers recommended this cam for stock compression/headed engines? I was actually considering gifting these to my dad for his stock 103 when I upgraded next year
Old 12-07-2012 | 09:58 PM
CigarCritic
Zippers does indeed recommend their 575's for a stock engine. That was due to lift clearances when they were first issued in 2008. You'll still have a turd without head word and higher compression running those cams. I would look to Wood Cams for better performance based on application.
Old 12-25-2012 | 04:04 PM
Roy D Route's Avatar
Roy D Route
I was just talking to the guys at MGS about a good cam to pair with their true duals and they recommended the RS575. Here's the quote, "Redshift 575 cams. No question. Awesome power curve. Stump puller." This was for stock heads in a 103 Streetglide, looking for strong 2500 to 4500 street performance. Why would they be recommending a turd?
Old 12-25-2012 | 04:13 PM
mgmmgm's Avatar
mgmmgm
Default Bump comp and head work
Yeah, I had 9.6:1 comp and Baisley Super Stock heads, and Baisley roller rockers- this was in my FLSTF 2007 bike 96" to a 103" build.
I would say TW 222 for touring bikes without the need for head work, see Fuelmoto web site for the
Dyno sheets on that cam in a 103.
Quick Reply: red shift 575 cams
