red shift 575 cams
Old 12-26-2012 | 10:57 AM
joee's Avatar
joee
the new flhtk i have is a 103 what i plan to do is have the street porting heads done at big boyz put v&h power duals with v&h hi output slip on tts tunner i trying to figer out if the rs575 cam will work good as
the build i had last year was a 106 with rs577 cams and worked relay well i am trying to get the 103 as close as i can
thanks
Old 12-26-2012 | 12:28 PM
bklynbob's Avatar
bklynbob
Default Long term reliability?
A high lift cam cam such as the 575 will stress the springs and wear valve guides prematurely. Not too mention the added stress on the bottom end. Miss a high rpm shift ,could be a problem. A 527 would give plenty of useable power if setup correctly............................
Old 03-22-2015 | 07:11 PM
soonerp's Avatar
soonerp
Default 2012 RK 103 with RS 575 cam see dyno
My ride stage one is jackpot downpine, se heavy flow breather, rush 4 inch slip ons. Cam install included 575 RS cam, adjustable push rods, new roller, and rs can tensioners. The work was performed by the dealer in idahofalls. I run the dyno at timp Harley in Lindon Utah because that's where the orginal dyno was run after stage one install. Just trying to minimize the varables.
C45H
Engine Mechanical Topics
12-21-2015 10:41 PM
jt metal
11-09-2015 09:26 AM
speakerfritz
08-19-2011 03:10 PM
DADAWG
Exhaust System Topics
11-21-2008 08:37 AM
sugarbear
11-08-2007 05:25 PM
Quick Reply: red shift 575 cams
