spark plugs
Old 12-03-2012, 08:52 PM
harrell42's Avatar
harrell42
harrell42 is offline
Default spark plugs
i read in a bike magazine that if you rounded the tip of your spark plug and set it about 2 thousands wider gap it would run better. anybody tried this i was going to try it any suggestions
roller
Old 12-03-2012, 09:02 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
in general- the widest gap possible is better...but too wide and it'll not fire...
and our modern ignition systems look for a certain amount of resistance in the plugs and wires, otherwise the computer may think that a misfire is occurring and retard the timing...
resulting in reduced power and MPG.
or start throwing codes
highly tuned race motors and street motors are different animals
our street bike ignition systems are really really good, light years ahead of just 20 years ago.
unless you have specific needs and a way to measure results, you may do best to leave it
Mike
Old 12-03-2012, 09:15 PM
Glockmeister's Avatar
Glockmeister
Glockmeister is offline
I've never heard of that, and while it might be a cool thing for YOU to try and report back to us on, I think I'll just leave my plugs set at recommended gaps and configuration.
In all seriousness, if you do try it, let us know what happens and whether you voided your warranty
Old 12-03-2012, 09:21 PM
fabrik8r's Avatar
fabrik8r
fabrik8r is offline
Google "side gapping"
Old 12-03-2012, 09:26 PM
harleycharlie1992's Avatar
harleycharlie1992
harleycharlie1992 is offline
Unofficial HDF Chaplain
Received 16,074 Likes on 5,006 Posts
used to do it on my 396 chev motor, hard to tell if it was better, it had a little under 600 hp!! sure it didn't hurt!!
Old 12-03-2012, 09:43 PM
btsom's Avatar
btsom
btsom is offline
A "rounded" center electrode is one of the descriptions of a worn spark plug. While the manufacturers may be trying to sell more spark plugs, they continue their explanation by saying that crisp edges on both the center and side electrodes promote an easier, better spark and that worn, round surfaces require more voltage to fire. Many people believe they feel the engine running better with new spark plugs. Aside from some accumulation of combustion deposits, the only real difference between new and well used plugs is the erosion which has happened to both electrodes thus rounding them and widening the gap. If you wish to "pre-wear" your plugs before installing them, it is your call.
Old 12-03-2012, 10:04 PM
fabrik8r's Avatar
fabrik8r
fabrik8r is offline
I'm not talking about pre-eroding your spark plugs, it's basically trimming back the ground strap to help "unshroud" the spark.
Old 12-04-2012, 12:40 AM
AlaskaAviator's Avatar
AlaskaAviator
AlaskaAviator is offline
two thousandths is pretty hard to feel. Doubt many here could do it.
Old 12-04-2012, 01:03 AM
drukanfu's Avatar
drukanfu
drukanfu is offline
Try these instead !
http://www.pulstar.com/
Old 12-04-2012, 04:14 AM
harrell42's Avatar
harrell42
thanks for input, think i will try the pulstar pulse plugs. has any body tried them
thanks roller
2011 ultra limited 103.
Quick Reply: spark plugs
