I installedmy PCIIIon my 07 RKthis past weekend. It was a piece of cake. Only thing I would suggest to be careful of is there'snot a whole lot of room beneath the side cover for the module and cables.
It is so easy, even I was able to do it. I am someone who is envious of cavemens abilities.
The unit looks easy enough to install, but what about the zero throttle setting. Did you do it running or with the 9v battery? Closed throttle only or closed and wot?
Hmmm....maybe I'm missing something too. I just plugged mine in and ran it. I didn't mess with the zero throttle setting on it. I figured jamie programmed it like it needed to be. Runs better than it did...maybe I should have read the instructions!!
