? For u touring folks
Good buddy of mine bought a 08 Street Glide with stock pipes and an S&S air cleaner already installed. When he installs new slip ons will be need a fuel pack of some kind?
I didn't think he would but I don't know enough about the S&S product line and I don't want to lead him astray.
Thanks
Thanks
Thanks
Thanks
I disagree. The bikes can make small changes, but both a/c and pipes are not small changes. One or the other, you might get away with it. But not both. I have the stock a/c and head pipes on my bike. I put a couple different slip-ons on it and it didn't really like them too much. The first set, without baffles, got a lot of decel popping and an occasional backfire. And no, there were no leaks. The Monster Rounds I have on now, also got a lot of decel pop. Remember, only changes to the bike were the addition of slip-on mufflers. Took it to the dealer and got the stage 1 download and the bike runs better than it ever has. No more popping, and where it struggled to get to 100 mph before (even with the stock mufflers), it now easily gets to 115. One of these days, I'm gonna be brave enough to see if it'll hit the 120 mark. I also get about 10 more miles to the tank now as a side benefit. The bike is an otherwise stock 96".
So in my humble opinion, a stage 1 download is the very minimum you should get when changing both a/c and pipes.
Thanks
Thanks
I have been running two different exhausts beside the stock, and an SE air cleaner setup. It has never been tuned and runs well. Pulls well above 100, and gets 37-40mpg around town and 46-49mpg on two lanes. 40-43 on the big slab @ 80+
It rarely pops under any circumstance and they are smaller pops unlike old backfires of yesteryear. It's my understanding the stock ECM can and does make adjustments on its own. My guy said "it adjusts to your riding style". And, when I asked him about piggyback plug in tuners, he said to stay away from them.
So my junk is going on seven years and no tuners. No issues either. But it is bone stock including tensioners @ 53K. Tensioners on slate for change asap.
That's all I'm going to say about that.
aka Bob
aka Bob
Not to send him spending too much - get a tuner, a custom dyno tune and swap cams. Then walk away from the SE or aftermarket world. I did the 120R. it's awesome, but the 96" with cams [26H] SE Heavy Breather, and SE Street Performance mufflers were more than sufficient - IMO.
I was 89 HP, and 100 ft-lb. I bought the TTS. And the Dyno tune sets it up perfectly.
