Traction Control Braking Device - Anyone use this?
I was surfing for information on Brembo brakes and came across this http://www.touringdepot.com/catalog/...55/5478241.htm
I have read several threads regarding retrofitting the Brembo ABS system. Perhaps this is an alternative?
Anyone using this?
Anyone using this?
Not sure there is a need for an alternative to the HD Brembo system, that is unless you don't have ABS at all.
I will be the first to admit that the HD Brembo system is, when compared to European anti-lock systems, not the brightest light on the tree. The HD system samples at a much lesser rate than a BMW system for instance. But as usual, Harley will do the absolute minimum to get by and then pass along the extra cost of doing it right to the customer.
Learning to use the brakes effectively and safely when you're learning to ride or drive trumps any mechanical/electronic aid IMO.
Back in the "olden days" when I learned to ride/drive ABS didn't even exist - nor did seat belts (in the '49 Dodge I learned in, when I was seven). You either learned how to use the brakes or you quickly busted yer ***! Those were the options. Very effective learning aid!
One thing that helped me was that the bikes I learned to ride on had such poor brakes that it was virtually impossible to lock the front wheel anyway - so there's that.
I did some more reading on their web site and they do have some good testimonials from Harley riders and some magazines, although ones I am not familiar with. I was hoping someone on this forum had already tried them. They do have a money back guarantee so I guess I will give them a call and ask more questions. I did find from further reading that they have a TCB II so I need to find out more about what was improved.
