Decreased MPG due to tempreture?
Old 11-26-2012, 05:57 AM
dohadex's Avatar
dohadex
dohadex is offline
Default Decreased MPG due to tempreture?
I live in the FL Panhandle where the temps have been in the 40s and 50's during the day. Since then, I have noiced my MPG has steadily declined from about 42 mp to about 34 mpg.
Just wondering if anyone else has experienced this? I've leaned out my map a little also...no effect.
Thanks.
Old 11-26-2012, 06:15 AM
Larry64's Avatar
Larry64
Larry64 is offline
To put it simply, cooler dense air needs more fuel to keep the air fuel ratio. There is a lot more to it with EFI, but the bottom line is you but more fuel in cold air. In cold Michigan winters I go down 5-7 mpg in my truck. A liquid cool engine is better at maintaining a constant temp. My small air cooled engines like my garden tractor really suck fuel in the cold.
Old 11-26-2012, 07:54 AM
jeg607's Avatar
jeg607
jeg607 is offline
Every vehicle I own from cars to planes gets poorer mileage in the cold - just the denser air.
Old 11-26-2012, 07:58 AM
jjnoble's Avatar
jjnoble
jjnoble is offline
It happens to me too.
Old 11-26-2012, 08:33 AM
edpnjax's Avatar
edpnjax
edpnjax is offline
The Ethanol in the fuel doesn't help either.
Old 11-26-2012, 08:46 AM
Python357's Avatar
Python357
Python357 is offline
Received 1,683 Likes on 678 Posts
Don't know if this is true in FL, but in MN there is a different blend of gas in the winter. Mileage drops 5-10% even if temps are constant, then add to that everything being cold and stiff plus the richer mixture because of the denser air and the longer warm up time.
Although at 11 degrees this morning, I did not want to find out what kind of mileage the bike would get
Old 11-26-2012, 10:46 AM
fwb35's Avatar
fwb35
fwb35 is offline
Yes, winter fuel with denser air will reduce mileage, I just checked mine and am getting 6 miles to the gallon less.
Old 11-26-2012, 10:50 AM
will2002's Avatar
will2002
will2002 is offline
Received 2,132 Likes on 1,030 Posts
THIS!
Old 11-26-2012, 10:55 AM
TWIN CAM 96's Avatar
TWIN CAM 96
TWIN CAM 96 is offline
Oil is thicker in cooler weather.
Old 11-26-2012, 11:01 AM
lionsm13's Avatar
lionsm13
lionsm13 is offline
Received 75,353 Likes on 22,641 Posts
I was wondering why my MPG had went down a tad..
Quick Reply: Decreased MPG due to tempreture?
