Getting harder to trust my service dept.
#31
#32
Clean off the threads and torque it to the spec of 14 ft lbs and forget about it. I change oil very frequently, and although not a good idea, I have yet to replace the rubber o-ring. And I don't use any thread dope or tape. Not needed. I think my o-ring is on it's 6th oil change and holding fine. Of course I inspect it, but if it looks good, it's going to get some more use. Rocket science this is not.
#33
#34
Those threads are def screwed up. They look like they were over-torqued. I'd be a little concerned about the female threads on the pan too. And that's def not build-up on the threads , it's some sort of Teflon tape, which shouldn't be used. I'll admit, I do use paste Teflon in addition to the new o-ring, every time I change my oil.
I am a machinist and I do threads all day.
Looks like a normal H/D drain plug to me how can you tell from a pic that they were over torqued? Maybe by tossing a pitch gauge on them you would have a better idea. I really don't think they look all bad but I will admit I am looking at a pic not the real deal. Thread sealant doesn't hurt a thing either.
#36
First thing look at service bill see if they charged you for new O-ring, if so you can't trust them because as ohioflhs says straight threads do not need to be sealed they use teflon, as a precaution because they did not change O-ring as book states but also you can get away with out changeing O-ring every time if you do changes yourself just inspect closely
#37
a few posts back it was sugested that the op get a dimple super magnet oil plug i think they ment these http://www.drainplugmagnets.com/harleydavidson.php
#38
