She sings in that cold air
Old 11-25-2012, 01:11 PM
Ben E's Avatar
Ben E
Ben E is offline
Default She sings in that cold air
Mid-30s today. She seems to really run well in this weather. i think part of it is the sound is crisper in the cold; but pretty sure she is breathing and preforming better too. Any science to this or am I just imagining it.
Old 11-25-2012, 01:18 PM
Airborne350G's Avatar
Airborne350G
Airborne350G is offline
Cooler air means denser air.
Old 11-25-2012, 01:19 PM
aktid35's Avatar
aktid35
aktid35 is offline
There is a little bit of science to it, cold air is denser more oxygen per cubic foot than warmer air. So you're burning your fuel more completely. Same reason guys with turbos run intercoolers. I'm going to ASSUME that the ECU takes temperature into consideration just an educated guess though. Plus sounds travels better in cooler air, I know that from years of running live outdoor shows. Plus your engine is also getting better cooling over the fins too. I can attest that my RK absolutely loves cool air it's very happy @ about 50*F. Never was brave enough to run @ 30* because we always seem to have this funny white stuff around here anytime its that cold....
Old 11-25-2012, 01:59 PM
ITOLDU's Avatar
ITOLDU
ITOLDU is offline
+1 on all the above, I love fall and winter riding and my scooter loves it even more.
Old 11-25-2012, 02:10 PM
Pastor Ed's Avatar
Pastor Ed
Pastor Ed is offline
Mine ran great Friday at 28 degrees. Seemed loader than normal:-)
Old 11-25-2012, 02:12 PM
YammyDrummer's Avatar
YammyDrummer
YammyDrummer is offline
Last bike loved 40*-50* and seemed to run it's best at those temps. The 103 in my new(er) RG seems to enjoy 55*-65*. You'd think it'd be the other way around.
Old 11-25-2012, 02:13 PM
o-townFLA's Avatar
o-townFLA
o-townFLA is offline
Cruising at 90mph never felt so easy in 30 degree weather...
Old 11-25-2012, 02:15 PM
Uncle Larry's Avatar
Uncle Larry
Uncle Larry is offline
Received 49,869 Likes on 19,345 Posts
The cold weather is great for the scooter, true enough, but it sure is hard on the old bones and joints ... after an hour ride at 37 degrees and it takes the rest of the afternoon to get "flexible" again ... but it's a small price to pay for "sanity"
albiker707 (11-22-2019)
Old 11-25-2012, 03:13 PM
Ben E's Avatar
Ben E
Ben E is offline
Lol Uncle Larry. It's the arthritic fingers that challenge me--otherwise okay anywhere above freezing.
Old 11-25-2012, 03:48 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,991 Likes on 4,182 Posts
Mine seem to run better the other day at 45 degrees. At idle I know I hear a little less racket going on. Mine is a little rich at idle and it hunts about 75 rpm. I also get a exhaust backfire quit often on startup so I think the injectors are leaking a little. That tends to make engine rattle. With the cooler denser air it is a tad bit smother. Always something however. I had just started it and as it idled down from 1500 to 1100 or so it shut off with a bump and blew the dip stick out. (it's a temperature one and has gotten a little loose) Hit the starter and cranked about 20 seconds and it was not firing. Keyed it off and on and re-hit starter and it started right back up..
Quick Reply: She sings in that cold air
