went down on new 07 street glide and why ????
#61
RE: went down on new 07 street glide and why ????
Had a similar situation happen to me except somehow when I felt the bike sliding right and getting ready to lay down I was able to come out of the skid and get her going in a straight line. I did however have to chose between hitting a truck or grinding my primary as well as my foot on a concrete median. Luckily I got away with a bent shift lever, groung peg and a foot missing quite a bit of skin on the top. Could have been worse...
Thinking of what I could have done different I came to the conclusion that I locked the rear brake (panic reflex) and was probably following a bit close given the traffic conditions.
hopefully I learned from my mistakes and won't repeat them...
Like some many have said before: ride long enough you will lay her down... let's hope we both have that check in the block and don't need to do that again
#62
First, I'm glad you're ok and it sounds like all possibilities have been covered. You may want to look at the road too - couldn't been dirt, patch, etc...
I'm very glad I opt'd for the ABS model mostly because of the high deer population here in Michigan. In this case, the anti-lock may have helped but everything happens for a reason and I'm just glad you're ok.
Now you get some upgrades compliments of your insurance company!
#63
ORIGINAL: SteelCityScooter
You "steer where you look", and with that said, you were looking at the car going to the left after impact and were steering to the left when your skid started kicking rear out to right.(At brake application)
Once your mind "felt" the skid, your instincts took over and you started a counter steer into the skid, and applied morefront brake.
Front wheel is now tuned to right, bike sliding right, front brake applied, over on the right side, she went.
At any speed if your front wheel is turn and you lock up, your going down. Seen it happen many times at Rider Edge classes and the instructor quotes to student "You can't lock up in a turn or stop with your wheel turned, your going down".
#64
#65
FFB, Glad to hear you're not seriously injured, Take the MSF Class with your relatively new scoot. Having ridden many motorcycles (as you have) the one thing I can say with certainty is each one handles DIFFERENTLY. The Harleys in general are heavier and take longer to stop even with the newer braking systems, providing you have suffienttraction. Also, newer Harleys offer anti-lock front/rear brakes. Got them on my '08 FLHRC and they are gold to a rider... Happy Trails
#66
ORIGINAL: ffb
electarick
experience is important ,and i have tons of miles and years under me.
i think that overall riding experience is not the issue here.
the problem ,i think, is my lack of experience with this specific bike , a harley. and the placement and reaction of the rear brake vis a vis the sports bikes .
so yes ,i lack experience with this brand ,but i plan to correct that ,and i had already modified the shifter so that it is less than 1/2 and inch under my toe. now i will go to work on the rear brake .
electarick
I designed and built the Evo and paid particular attention to not overbraking the skinny 21"(early FL type 2 disc)and having a very progressive and smooth rear brake(Willwood, ceramic pads).
In a recent accident(left turner) it paid off. I was able to brake hard and steer, avoiding a Tbone(but catching her rear bumper with my leg).
There was no reaction time, I went into auto mode immediately without thought, cranked akneedragging leftand the bike responded well.
Practice, practice and practice some more!
#67
ORIGINAL: gunrunner
As others said, too much rear brake, most people tend to rely too much on the rear, some say its from a mindset of old pictures of dirt bikes and guys going over the bars by grabing too much front brakes. This wont happen on a big bike, most of your stopping power is in the front. Dual discs on big harleys will bring her to a safe stop when used with some rear brake pressure in most cases with no loss of controll.
#68
ORIGINAL: HardCore_18
You hit your front brake into the lean , did'nt you? that would cause the bike to go straight down to the ground. depressing your back brake gently would cause the bike to stand straight up.
other things that I wonder about your situation, was the road crowned - therefore assisting the "slide-out" of the front wheel? if it is a slowly traveled city street, was there oil and gunk on the road that does not wear off due to slow traffic?
#70
ORIGINAL: Ultrasweet
Good case for ABS. For the times when you screw up, ABS can save your ***.
