Apes install, wiring connector questions.
Got the wires pulled. Getting ready to reinstall the connectors after I eat this lunch. No dealer in the STATE has one of those connecters so I am going to try
moving the wire to a spare hole. If I cant Ill just have to order one.
Its an 09FLHT and I am using Wild1s 12 1/2" bagger bars. Dunno the number.
It, may not relate to your project but....
There seems to be a technic when working with the electronic throttle control wires. They need to go in first. They will go past the first bend. Then the "other cable of wires" will go through the first bend and past the throttle wire connectors. If one tries to put the throttle wire connectors in after the "other cable of wires" the connectors will not go past the first bend. The "other cable of wires" take up too much room for the connectors to pass in the bend. But if the throttle wire connectors are past the first bend the "other cable of wires" have sufficient room to make it through the bend and then past the throttle wire connectors. This took me about 2 hours to learn.
My write up for whe I put on new bars is here;
There may be something there to help you.
ALL DAY is how long it took to reassemble all the connectors. WHAT A PAIN IN MY ****ING ***.
But the bars are on, the inner fairing is on. Tomorrow is exhaust, clutch cable and brake lines and button it all up day.
Have any of you guys who have used the bigger diameter bars been able to use the rubber pieces that fill the gap between the dash and the bars? I cant get the dash to fit with the rubber in place.
Mike
sixshooter
01-30-2011 07:56 PM
