OK Screwed up and need help
Old 11-24-2012 | 11:09 AM
Bowhunter61's Avatar
Bowhunter61
Originally Posted by im
This happens more than most want to believe and it is very easy to strip.
The choices are pretty much what you linked to: over sized, piggy back and then what is sometimes the overlooked option of a slightly longer drain plug bolt..If you go to NAPA autoparts with your original drain plug the counter person will measure the plug for you for diameter, thread type(course/fine) and pitch.
From my experience:
1-over sized piggy back sometimes creates a clearance problem on some bikes when using a floor jack and is very deep when compared to your regular drain plug thus eating alot of good threads. Also the provided o-ring sucks.
2-the 1 time oversized magnetic drain plugs are very good IMO, do not eat away a bunch of good threads and look factory to the naked eye just in case that is important to you.
3- a longer NOT over sized drain plug would catch/hold onto deeper threads in the case but will not have a magnet and the head size of bolt will be smaller..just information not that it matters.
*Finally: none of the above choices allows for an o-ring but the use of white liquid thread sealant solves that problem....there are individuals that have ground a small o-ring slot with a dremel type tool for #3
In an emergency situation i have seen someone just remove the o-ring and put teflon tape on the original plug. removal of the o-ring allowed the plug to sit a little deeper and bite into a good thread.
But your best bet might be NAPA although they might cost $8 instead of $3 at advance/pep boys or other place but they usually have informed counter people.
Torque wrenches sometimes become an issue with drain plugs because of positioning and low torque values. Hand tight and then quarter turn with a small 1/4 type wrench.
Thanks IM, this has me rethinking my approach now. I think I will run up to NAPA and see what they have and go from there. The longer plug may be the right way since I do have some good threads left in the pan that the original plug is getting too, so a longer plug may work.
Old 11-24-2012 | 01:27 PM
Bingee's Avatar
Bingee
If you have good threads left you should be able to use a tap to dress things up so you can use the original plug. It's worth a try. It's easy to do. And it's cheap.
Old 11-24-2012 | 01:39 PM
Bowhunter61
I thought of that first, but the problem is the first 2-4 threads are not there, they came out with the plug. So I only had have the threads there and those were OK, plug screwed in fine.
I did get the longer plug and it seated tight so I think I am good to go, I am letting the thread sealer set and I will fill with oil and see if I have any leaks.
Thanks for all the suggestions guys
Old 11-24-2012 | 04:05 PM
AlanStansbery's Avatar
AlanStansbery
No one mentioned a Heli-Coil. (Maybe there's a good reason for that...) I have installed Heli-coils in aluminum where the threads were problematic, and had excellent results, i.e., no further issues.
I would think you could do the job with the pan on the bike...just pour some oil through to wash any metal chaff out...shouldn't be much anyway, though. I recall the process is drill, tap, insert coil. Then you have metal threads set into the aluminum.
Alan
Old 11-24-2012 | 04:32 PM
rg_dave's Avatar
rg_dave
This happened to me on my primary. Everything seemed normal. Never even got tight. The threads just spun right out and came out with the plug. I went with a one over from the the auto parts and all is well. 30 thousand miles ago and several changes.
Old 11-24-2012 | 04:37 PM
im's Avatar
im
That should work fine. A step up would be to grind the base of the bolt just under the head to permit the use of an o-ring...maybe a future project when you see that it all works out now.Then just buy a second plug and use a dremel type tool or maybe a friend has such a tool and use the second drain plug when you change the oil next time.
Old 11-24-2012 | 05:46 PM
Leftcoaster's Avatar
Leftcoaster
Hope you weren't using thread dope on that plug - it doesn't need it and it only causes problems just as you describe. Thread dope plus a torque wrench equals trouble when it comes to drain plugs with o-rings. A new o-ring and snug should be all you need.
Old 11-24-2012 | 08:40 PM
Glockmeister's Avatar
Glockmeister
Originally Posted by Leftcoaster
...A new o-ring and snug should be all you need.
This is what I do.
Old 11-24-2012 | 11:15 PM
Fishrrman's Avatar
Fishrrman
'Not sure how this happened, I started it with my fingers for the first 3 full turns and then was using a torque wrench to tighten'
The LAST thing anyone wants to do is to use a torque wrench on the oil and transmission drain plugs.
You don't even want to use a socket wrench or even a "regular" (open or box end) wrench on them.
Look at the end of the drain plug -- it's got a 1/4" allen-head wrench hole there.
Thread the bolt in by hand as far as it will go, then take a small L-shaped 1/4" allen wrench, put the small end of the "L" into the hole, and "hand-tighten" it. You will get it tight enough, but the small wrench means you won't over-torque it and strip it out.
I've done this for years, and NEVER had a problem with a loose bolt later on. Never stripped a thread, either.
Old 11-25-2012 | 12:18 AM
karbar99's Avatar
karbar99
I disagree. Per the instructions in the service manual the torque is 14-21ft lbs. Have reinstalled many plugs with these torque values and not once had a problem.
Quick Reply: OK Screwed up and need help
