Power Commander III problem with throttle position
I recently installed V&H Big-Shot Dual & V&H Nake A/C along with a Power Commander III USB system on my 08 Road King Classic. I've tried to set the Throttle position but when I plug the PC into my laptop using the PC software it shows the Throttle Position to be at 100% on the indicator even with the throttle closed...and the indicator does not move when I roll it. It will not change when I reset Throttle position. However the RPM, fuel...etc are live/real-time. The bike is running though not as good as it should...sometimes popping on deceleration.
Has anyone had this problem with throttle showing constant 100%?
Note: I'm using MAP 818-030
I concern because I bought the PC used off of Ebay...
Thought I got a good deal ($130.00) but you know what they say.
But hey...the pipes & A/C are new.
Any help is appreciated.
bmkbailey
V & H Black Big-shot Duals
V & H Naked V02 Air Intake
bmkbailey
Thanks.
Thanks for the help.
On 08 Touring models with PC III USB you cannot set the open throttle setting unless the bike is running and under a load (i.e on a dyno) due to the drive by wire system. Also make sure that when you set the closed setting that the bike us up to operating temp as the TB steps the throttle blade open slightly during warmup.
Because you have reset the the throttle position settings you will need fix this, but not to worry it is easy. In the PC III software go to Power Commander Tools>Set Throttle Position and you will first enter the value manually to the "Open" box which is 28024, you can then enter the Closed value to 5536. You can then get the bike to full operating temp, connect the software and make sure it reads 0% at idle. If necessary you can go to Throttle position and match the Closed value with the "Current" value and it will sync the closed throttle position to 0% at idle. Hope this info helps
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
