Service manual torque value....THIS CAN'T BE RIGHT
Old 11-14-2012, 12:17 AM
0ldhippie's Avatar
0ldhippie
0ldhippie is offline
Originally Posted by craigffb
If you know so much then you should have know why the question was even asked and gave some useful input instead of use the manual, so suck it old man. You have anything else to say PM me teach.
I've got the answer I was looking for....Thanks for your insight
You've been PMed. I know why the question was asked, because you're an idiot. Wow, ya got an answer ya were looking for, nothing else counts.
  #32
Old 11-14-2012, 12:47 AM
Uncle Chester's Avatar
Uncle Chester
Uncle Chester is offline
This has been the funniest thread I read all day. Thanks guys for giving me a good laugh, OP my wife said Midol will help with those cramps.
  #33
Old 11-14-2012, 01:16 AM
craigffb's Avatar
craigffb
craigffb is offline
Originally Posted by R0UNDAB0UT
No useful input here - just reminded of a quote from the Overly Manly Man.
Seriously, good luck with your quest.
Classic
Originally Posted by dickey
Better to undertorque & have a little weepage than bust out a thread.
I could not agree more.
Replied. Thank you again for all your helpfully and informative insights.
  #34
Old 11-14-2012, 01:48 AM
drukanfu's Avatar
drukanfu
drukanfu is offline
http://www.engineersedge.com/calcula...orque_calc.htm
So....the difference of max torques suggested is 38 inch lbs. or 3 ft. lbs. additional torque.
The difference in clamping force 3120 ft. lbs - 2400 ft.lbs = 720ft.lbs / 3 ft. lbs = 240 ft.lbs more , which is only 2.4 % .
Bolt torques weather grade 5 or grade 8 are rated at only 80% of their value.
You will be ok at the higher torque given..........which is all just a pinch of **** !
  #35
Old 11-14-2012, 02:14 AM
Glockmeister's Avatar
Glockmeister
Glockmeister is offline
Originally Posted by BBStacker
Without getting into a pissing contest....Working on your bike and designing them are horses of a different color.
Mech, tech, backyard mech, Mongo turn bolt.
Engineers that design and figure out all the nuances for lack of a better word.
Just because it's same size bolt doesn't mean something didn't change between year models.
I need more pics of the bike in your sig plz!
  #36
Old 11-14-2012, 09:04 AM
fabrik8r's Avatar
fabrik8r
fabrik8r is offline
Very nice! There is almost always a reasonable solution if you look in the right place for the answer. Excellent research.
  #37
Old 11-14-2012, 10:59 AM
0ldhippie's Avatar
0ldhippie
Exactly! Just because fasteners are the same size doesn't mean they require the same torque. Engineers actually spend some time figuring these things out.
  #38
Old 11-14-2012, 11:13 AM
AtkRWC's Avatar
AtkRWC
AtkRWC is offline
Tell that to the tech next time your drop your bike off to have the oil changed.
If they have to drop their bike off to have the oil changed, most likely don't know what torque is anyway! ;-)
  #39
Old 11-14-2012, 11:28 AM
JerryS63's Avatar
JerryS63
JerryS63 is offline
I think the guy is wise to question it. Would not be the 1st typo in a manual. Those that leaped on the guy, Yep Midol might be the answer!
  #40
Old 11-14-2012, 11:51 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,859 Likes on 1,289 Posts
I know some engineers, and I know some arrogant engineers, I can easily see a new engineer stepping in beating his chest and changing a torque value to show his worth. Most all of our 1/4-20 bolts for covers in non-pressurized situations are 130 inch pounds. We have not been around as long as Harley but we have been around long enough to teach some of their snot nosed engineers on a budget how it's done. Just my arrogant 2 cents.
Quick Reply: Service manual torque value....THIS CAN'T BE RIGHT
