Service manual torque value....THIS CAN'T BE RIGHT
Old 11-13-2012, 05:59 PM
craigffb's Avatar
craigffb
craigffb is offline
Originally Posted by Drat
I just checked the 2011Touring manual and its listed as 108-120 in lbs. Follow your manual is the best I can tell you.
Thanks...That's what I figured.
Originally Posted by Coolhawg6622
Quit second guessin it and torgue it on! Done..... Geesh quit over thinking it....
Tell that to the tech next time your drop your bike off to have the oil changed.
Old 11-13-2012, 06:04 PM
HD1998FatBoy's Avatar
HD1998FatBoy
HD1998FatBoy is offline
Stage II
My 1998 FLSTF calls out 10 Ft lbs which is equal to 120 in lbs. Hope this helps???
Old 11-13-2012, 06:15 PM
NorCalFBLO's Avatar
NorCalFBLO
NorCalFBLO is offline
2013 Road Glide manual says 12-13 ft-lbs, 16.3-17.6 Nm, so same as 156 in-lbs
Old 11-13-2012, 06:21 PM
Stiggy's Avatar
Stiggy
Stiggy is online now
Received 5,818 Likes on 3,172 Posts
People use in/lb torque wrenches when installing simple covers now?
I'm gettin' old I guess...
Old 11-13-2012, 06:23 PM
harleycharlie1992's Avatar
harleycharlie1992
harleycharlie1992 is offline
Unofficial HDF Chaplain
Received 16,074 Likes on 5,006 Posts
don't go there!! I've tried, you will get the evil stink eye!!
Old 11-13-2012, 08:29 PM
craigffb's Avatar
craigffb
craigffb is offline
Originally Posted by fabrik8r
Identify the thread size, then check a "generic" torque chart, if it isn't higher than that, it should be ok. My 06 calls for 84-108 in/lb, so there is obviously something different among the models/years.
I didn't even think of that...good ideal...so I looked it up:
the bolts are 1/4 - 20....85-125 in lbs
Old 11-13-2012, 08:48 PM
fabrik8r's Avatar
fabrik8r
fabrik8r is offline
Cool, was that the grade 5 or grade 8 chart? It depends on where you look, this grade 8 chart says 12 ft/lb or 144 in/lb. http://www.portlandbolt.com/technica...que-chart.html.
this one says 13 ft/lb
http://www.zerofast.com/torque.htm
Never just a simple answer, is it?
Old 11-13-2012, 08:59 PM
CHILLLS's Avatar
CHILLLS
CHILLLS is offline
i didnt read all the posts but i just came in from servicing my SG & adjusting my clutch. my 2011 manual states 108-120"lbs.
i did mine to 120"lbs
Old 11-13-2012, 09:03 PM
iclick's Avatar
iclick
iclick is offline
The '07 and '10 Touring manuals say 108-120 in. lb.
Old 11-13-2012, 09:12 PM
BBStacker's Avatar
BBStacker
BBStacker is offline
Without getting into a pissing contest....Working on your bike and designing them are horses of a different color.
Mech, tech, backyard mech, Mongo turn bolt.
Engineers that design and figure out all the nuances for lack of a better word.
Just because it's same size bolt doesn't mean something didn't change between year models.
Quick Reply: Service manual torque value....THIS CAN'T BE RIGHT
