Heated gear
#41
#42
I started out with an old heated blanket that the controls went bad, I picked it up at the local goodwill store, for a buck. Pulled the wires out and just started playing around with the wire length until I found a length that got the temperature that was comfortable for the application.
Heated grips you want hotter than a heated coat. 180 or so for the grips 140-150 for the jacket. The shorter the wire the hotter it gets.
The grips I just wrapped them and then covered them in leather, the jacket I threaded the wires into the liner.
Doing some head gear the hardest part would be getting the right length for the wire, since it would be so short a wire, you would need to wire in some sort of resistor to cut back the voltage or it would get way to hot. That and it would get pretty thick because of the material that you would have to put the wires in.
You could maybe put the wires inside the helmet.
I go into it in more detail on the grips in my build site link posted below on page 29-31, the jacket is page 42.
I have been running the grips for two years and the jacket for one. They both work great, and yes I ride in twenty degree weather quite a bit.
#43
Well I have made heated grips and a heated jacket. I thought about doing it for years before I actually did something.
