Does an inch really make a difference?
Putting on Ohlins (or maybe JRIs) and monotubes this winter and need help deciding whether to lower an inch. I can just barely flat foot with stock and would enjoy being an inch lower; but agree with a lot of posts i read about the more clearance the better for leaning/turning. I do long tours and like the twisties too.
I have never riden a lowered machine and don't have a source to compare. To lower or not to lower? Can you guys weigh in?
Much thanks.
Benny
Much thanks.
Benny
These shocks rose the riding height as expected, but the ride is superb and it put the stroke up enough to eliminate bottoming and most any semblance of a rough ride. In fact, the ride is so velvety smooth it extends my riding tolerance by hours. My inseam is 30", I have no problems with the bike's height as it stands now, and I can barely flat-foot the bike at a stop. IMO if you skimp too much on riding height you pay for it in comfort, all other factors being equal. I would recommend buying the tallest shock your leg length can tolerate, and would definitely recommend calling Howard at Motorcycle Metal for his advice.
[QUOTE=iclick;10516459]I started with the stock 12" SG shocks and after having my tailbone knocked into my Adam's apple too many times from potholes in our substandard LA roads I decided I needed more shock travel. I next went with 12½" Progressive 440's with standard springs and there was some improvement, but I thought there had to be better options available. My second and last venture into shock swapping was in 2009 when I installed some Ohlins 2-3, which are 13¼", and that was the sweet spot for me.
for his advise.[/QUOTE
+1 on this.
Lowered my RK 1" and it was great at a stop flat footed and loved it, but the ride was terrible and cornering suffered. Went to Works 13" shocks and that improved the ride and cornering clearance, but I felt the ride could be better. Gave Howard a call and now have the best ride. When I traded in my RK for the RGU I kept the shocks and put heavier springs on to handle the heavier bike
+1 on this.
