my bike is sick.
my bike is sick.
Went on a day trip the 1st. Was running down the highway perfectly at 70 then all the sudden she backfired and died. now it will crank but sounds like only firing on one. will not idle, little it will shakes to be damned. Put a dampener on an other wise PERFECT DAY. where do I start looking. I am afraid it jumped time. thats how it acts at least. if it is a major problem it will be 4 to 6 weeks before I can put in shop. At that point I am thinking of just getting a 1800cc 110ci engine and 6 speed gear box. Bike is an 05 ultra classic with 44k miles. just got it in April and have not put an abundance of miles on her. Any thought would be a big help. I do most work myself,that I feel good about doing with out complications.Thanks.Dale
No need to go in to Panic Mode..It could very well be an easy fix..44,000 is not a lot of miles..What is the maintenance history of the bike ? Have the cam chain tensioners been looked at or replaced ?
check for codes first, that will get you in the right direction.....it sounds electrical to me...running fine and just dies....usually fuel problems will run weak or it will sputter before dying....look around and check all the plug connections..take them all apart and re-seat them all...also fuses...it could be something as simple as a frayed wire somewhere ...but first check for codes....
