Air Pressure in Shocks???
Old 09-01-2010, 03:23 PM
RedRedLTD's Avatar
RedRedLTD
RedRedLTD is offline
We ride two up loaded and were bottoming out on big bumps. On our last trip I bumped the pressure from 20 to 30 psi (50 psi max for 2010) and it made a huge difference. No more bottoming out. I bought the harley pump.
  #52
Old 09-01-2010, 03:47 PM
DuckDolan's Avatar
DuckDolan
DuckDolan is offline
3rd Gear
Originally Posted by Stash
Thanks, I must be a little dyslexic. I looked earlier and couldn't find any reference in the index. Sounds like I need a pump or a diet. My once high school trim and fit 160lb body has deserted me and left a 200lb beast.
I have the exact same problem! And my wife, well, nevermind...
  #53
Old 09-03-2010, 10:08 AM
Outlaw7x77's Avatar
Outlaw7x77
Outlaw7x77 is offline
Wink Success Story!!!
See, It works!
  #54
Old 09-03-2010, 12:16 PM
cayers's Avatar
cayers
cayers is offline
Listen guys, even if you get the "same" pump as the Harley version.....it doesn't have the Harley shield in the gauge and besides using a non-harley version will void your warranty.
  #55
Old 09-04-2010, 03:00 AM
Robert_W's Avatar
Robert_W
Robert_W is offline
"which could result in death or serious injury."
Ride safe,
Bob.
  #56
Old 09-04-2010, 07:01 AM
SUPRPIG's Avatar
SUPRPIG
SUPRPIG is offline
Went to the dealership for a service and asked them to check the Shock Pressure. Came back with "it's fine it's 12 lbs." Checked my manual and bought the pump. I needed to be running around 30... 12 would be good if I were around 150 lbs. Check the manual and buy the pump... love it and coinvienent. Much improved ride.
  #57
Old 09-04-2010, 07:18 AM
shortride's Avatar
shortride
shortride is offline
Here's a H-D pump for $39.96
  #58
Old 09-04-2010, 07:23 AM
CapeGlide's Avatar
CapeGlide
CapeGlide is offline
Hey guys. It seems I'm pumping up the shocks every 2 weeks or so. Is this normal?
  #59
Old 09-04-2010, 07:43 AM
vonzoog's Avatar
vonzoog
vonzoog is offline
From what I hear it is not uncommon.
I move the pressure up to 40 for two up riding and back down to 12 -15 psi for solo riding. But I do this at least a couple times a week and I have not shown any pressure loss between changing. I believe that if you set the pressure at one setting and rode for long periods of time without changing the pressure eventually there will be a pressure drop. Just like your car/truck/bike tires will lose some pressure over time.
  #60
Old 09-05-2010, 08:25 PM
Robert_W's Avatar
Robert_W
Robert_W is offline
I would expect air temperature changes may make a difference also. Just like our tires.
Ride safe,
Bob.
Quick Reply: Air Pressure in Shocks???
