Air Pressure in Shocks???
Old 01-30-2007, 09:33 AM
jmorton10's Avatar
jmorton10
jmorton10 is offline
Default RE: Air Pressure in Shocks???
Another option is to replece the crappy HD air shocks with either Works or Progressive 440 shocks. Either of these will dramatically improve the ride quality & are easily adjustable by hand with no tools required.
I replaced the stock shocks on my 04 RK Custom when it was one week old(I used 12" standard spring Progressive 440's)& sold the stock shocks on ebay for over $200, if I bought a new dresser tomorrow I would replace the shocks right off.
~John
Old 01-30-2007, 11:01 AM
Arizona's Avatar
Arizona
Arizona is offline
Do you have to remove the saddle bag to access the valve? I plan to get the pump and air up to about 20 pounds, but heard the bag has to come off to get the pump on the valve correctly.
Old 01-30-2007, 01:03 PM
iclick's Avatar
iclick
iclick is offline
ORIGINAL: Stash
I have been trying to purchase an inexpensive air pump to regulate the pressure in my shocks. The Harley pump is $39.95 and has a 0-60psi measurement. I have seen others that are less money, but only have a 0-30 psi gauge. I looked in my manual, but could find no recommended air adjustments. I have never adjusted mine and never checked to see how much air I'm running. How much air is needed for average two-up running? Do I need to adjust for a trip where I'm carrying extra weight. How often are you guy's adjusting air pressure? Do I need a pump? Any recommendations?
The '07 specs must be different, because for my size (170#) the recommended pressure is 0-10 for the SG. The FLHRS and FLHX have different specs from the other bagger models, BTW. I have it set on 5# and am thinking about going to 0, as the rear suspension is a bit stiff, more than it needs to be. When loaded for touring I'll bump it up. The specs are in the owner's manual (p. 56), and these are for your FLHTCU and all except SG and RK Custom:
Solo, up to 150 lbs.: 0
Solo, 150-200 lbs.: 0-10
Solo, 200-250 lbs.: 5-15
2-up, passenger up to 150 lbs.: 10-15
2-up, passenger up to 200 lbs.: 20-25
Since you likely will never use pressures >30 psi, it would seem the 0-60 range is overkill. I have a Progressive pump I've had for 10 years, and is very similar to the HD model. It also cost $40 even back then, but it was about the only one available, as HD didn't offer one.
Old 01-30-2007, 01:49 PM
GTK's Avatar
GTK
GTK is offline
You get what you pay for,Go with the HD pump
Old 01-30-2007, 01:59 PM
bluesgub's Avatar
bluesgub
bluesgub is offline
I run 10lbs. single, 18 double. Get the HD Pump. It's well made, has a built in gauge, designed for the application, and fits into your tool pouch. Designed for low pressure, low volume applications. Gas station pressure pumps are for high pressure.
Old 01-30-2007, 03:05 PM
iclick's Avatar
iclick
iclick is offline
ORIGINAL: bluesgub
Yeah, you can blow out your shocks if you try to use commercial compressors designed for tires that go far higher than is recommended. With so little volume, it doesn't take much time to over-pressure them.
Old 01-30-2007, 03:38 PM
Sreynold1's Avatar
Sreynold1
Sreynold1 is offline
No yu do not need to remove the hard bag. You do have to open the lid to gain access.
Old 01-30-2007, 03:47 PM
alexcue's Avatar
alexcue
alexcue is offline
ORIGINAL: Sreynold1
Yup, easy as pie!, and recommend the HD pump, small and fits into the tool bag, and doesn't bleed air when connecting or disconnecting.
My '07 Ultra runs at 25lbs single up and 35lbs in 2-up full weight mode! Per manual (btw, we ain't no lightweights)
Old 01-30-2007, 04:27 PM
tphillips's Avatar
tphillips
tphillips is offline
In addition to all the good advice listed above, I would add that it depends on the kind of riding you are doing. When we (wife and I) are on the highway with loaded saddlebags, full tour pac, and extra bag on the carrier, we are adjusted for comfort -- about 20 lbs. air. Good ride, nice and smooth over the expansion joints and all the road imperfections. But when we get to the twisties and offload the luggage, I stiffen up the shocks for better response, less wallow in the corners, and quicker response on the overall handling of the bike.
Solo I ride with about 5-10 lbs. of air -- and I'm right at 200 lbs. Good overall setting....
Hope that helps!
Old 01-30-2007, 05:21 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
IAMSWUTIAMS is offline
[sm=icon_rtfm.gif] and Get the HD pump!
Quick Reply: Air Pressure in Shocks???
