Cannot get the heat shields installed. HELP
My .02 cents worth!
First, the last picture you posted shows the inside of this small heat shield, there is an "H" shaped bracket welded on the inside/underside of the heat shield. The stainless steel hose clamp that holds this onto the pipe should go between the bar connecting the two uprights of the "H" and the heat shield. You have to unscrew the stainless steel hose clamp so it opens up and you can insert the one end through this opening.
Secondly, it looks like, based on picture one and two, this short heat shield may fit under the two heat shields on either side of the motorcycle in question.
I could be wrong though.
Good luck!
GSF
Good luck!
GSF
