Engine mods.
10-30-2012 | 02:43 PM
Engine mods.
Seriously considering the R&R cycles 103 stage V upgrade.
10-30-2012 | 02:48 PM
I say go for it, let us know how it works out.
10-30-2012 | 04:09 PM
you can get some good gains from a properly build 103", but why not go with a 107"? 103's come stock these days.
10-30-2012 | 04:31 PM
i was looking at the R&R set up and it seems they get great #'s from the 103 set up. about the same as a 107. Plus they are close to home.
10-30-2012 | 06:14 PM
Makes sense. I'm running R&R heads. Solid reputation and you support your local business.
10-30-2012 | 06:34 PM
Fuel Moto has some really good kits for the new 96 and 103 engines
10-30-2012 | 08:44 PM
I have a 2011 103" for sale and i'm around the corner from you, if you want a 103.
10-30-2012 | 08:52 PM
WELD THE CRANK and make the bottom end solid. or you will wish you had
10-30-2012 | 08:55 PM
What will the compression of the motor be?
10-30-2012 | 10:46 PM
I believe the compression will be 10.5
