Rear Wheel Removal ...Best Way?
Old 10-31-2012 | 12:38 PM
stupid_rope's Avatar
stupid_rope
no need for any special tools. if youre worried about it, sharpie mark the axle cam position and put it back to that mark
Old 11-01-2012 | 10:47 AM
hardheaded's Avatar
hardheaded
i am tool crazy, anything that makes it easy and gets it dead nuts on, i like.like making my own tools if i can.been thinking about making wheel bearing tool for these new bikes as it looks like i will be using it alot.
Old 11-02-2012 | 10:42 AM
Bingee's Avatar
Bingee
So far it looks like the best way for me to get the wheel off is to jack up the bike on my lift. Loosen the right side muffler and push it to the side so the axle can clear it on the way down. Slide my other jack in to hold up the wheel. Disconnect both shocks. Lower the wheel. Remove the axle and other hardware. Remove the wheel. Seems simple enough.
Old 11-02-2012 | 11:37 AM
fat daddy's Avatar
fat daddy
Why take the shocks loose ?
Old 11-02-2012 | 11:45 AM
fat daddy's Avatar
fat daddy
Also you might want to block up the front. Wheel so when you take the weight off the rear it will remain steady.
Old 11-02-2012 | 11:57 AM
Bushy's Avatar
Bushy
that special wrench comes in the tool kit if you got one from HD
Old 11-02-2012 | 01:20 PM
Bingee's Avatar
Bingee
The axle is in direct line with the mufflers. I don't want to remove the mufflers. So the only way to get the axle out is to lower the wheel so that the axle is completely accessible from both sides. With the shocks disconnected the rear fork/wheel can drop down to allow access. This seems to be the way it is done in the HD shops.
Old 11-02-2012 | 01:24 PM
Bingee's Avatar
Bingee
Once the axle is below the mufflers I can just use my 1/2" torque wrench and a 36mm socket.
Old 11-02-2012 | 03:39 PM
fat daddy's Avatar
fat daddy
OK I got ya . I have Vance & Hines big radius on my bike so I didn't have to deal with any mufflers, real easy job
Old 11-03-2012 | 05:44 PM
mikelikesbikes's Avatar
mikelikesbikes
Bada Bing!!!! We have someone that has actually done this before!!!!
Quick Reply: Rear Wheel Removal ...Best Way?
