98" build
RE: 98" build
Your one step ahead of me. I am waiting for my parts to arrive in the mail before I go any farther. Are you planning on installing the pistons in the jugs before attaching them to the connecting rod? Are the c-clips for the new pistons different than stock? If not I can see I will have some fun getting those back in.
RE: 98" build
ORIGINAL: Abnmarine
I'm waiting for you to do the six speed?!
RE: 98" build
I'll get the engine back together before I tear into the tranny. I'm already out of room on my workbench.
ORIGINAL: Fandango6
Yes, that is the plan, and I'll check on the c clips, don't think there is any difference, but there still in the packing right now.
ORIGINAL: Abnmarine
RE: 98" build
the wristpin clips are simple to install (right Dawg?).
Be sure to install one for each pistion on the bench, before sliding the piston(s) in the cylinder(s).
With the piston/cylinder in place and wristpin lubed & fully instered through piston & rod, all that's left is the clip ~ WAIT, don't forget the o-ring on the base of the jug!
Looking at the wristpin hole in the side of the piston, you'll see a notch, usually @ about 7:00. To the best of your ability, "pinch" the clip closed and insert it with the opening (opening in the clip)180 degrees from the notch. Using an awl with the tip in the notch, simply snap it in. It's really simple.
Another saftey measure.... don't take the rags out of the bores arounf the rods until after you've snapped the clip in place.
RE: 98" build
ORIGINAL: PhilM
RE: 98" build
You make this sound so easy.....
Those little boogers flew everywhere when I was taking it apart.
Wish they used c-clips (spiral locks) like what was on my H-Beam rods.
ORIGINAL: PhilM
Tn.Heritage
Exhaust System Topics
11
02-24-2008 11:39 PM
