Fuel Gauge issue
Fuel Gauge issue
Does anyone know of a way to adjust the fuel gauge, or float (assuming there is one) in the tank for the fuel gauge? It doesn't matter if I'm running around in the city two-up getting 36 MPG or if I'm cruising on the highway along getting 43 MPG, pretty much at 160(ish) Miles on the trip meter, my low fuel indicator goes on. Today it happened, and I was by a gas station, and was only able to put in about 3.74 gal of fuel into the tank. It's driving me nuts.
Thanks,
mikebaby
Thanks,
mikebaby
I've never had a fuel gauge on a motorcycle worth a mention. They all sucked. Even on all three HDs I've owned previously. Best thing you can do is know your bike. It drives my wife crazy because I'll ride for an hour with the low fuel indicator on!!
Kind of curious if you can fix it too. I've always just lived it.
While this may be a viable work around, I would raise hell with HD and not stop until I got an acceptable answer. You aren't the only one to find issue with HD fuel gauges and wont be the last.
I've seen this topic quite a bit in the five months I've been on this forum. My own opinion on HD fuel gauges leans towards additional fluff that helps sales, since based on your post and myriad others - they are no where near accurate and therefor, useless.
This keeps coming up - it's driving ME nuts! In the past we had a reserve position on the gas tap, which told us we could carry on riding with around a gallon in reserve. Now we have a light that comes on when we have around a gallon in reserve. What's the problem?!
If you want to adjust when the light comes on, the float inside the tank is on a piece of thin wire. You just have to get in there and play with it until you are happier.
Lmao with EricD10563 .....yup again its a Harley, that's why we love em. Here's what i did. 6 Gallon Tank X 30 mpg= 180 miles. Set my trip odometer to 0 when i fill up, When I hit 180 Miles I start looking for a gas station, At 210 I really start looking , At 240 I hope theres on at the bottom of the next hill. Good luck with that Gas Gauge.
