Dyno results with duals to 2-1. Shocking!
Old 10-25-2012, 06:34 PM
MichiganRider's Avatar
MichiganRider
MichiganRider is offline
Default Dyno results with duals to 2-1. Shocking!
Back in April I had my bike tuned after I installed a set of Andrews 48H cams. Rinehart Extreme duals with 4" mufflers.
I'll attach the sheet.
Next post will be the results of another tune with the only difference being a 2-1 pipe.
Attached Thumbnails Dyno results with duals to 2-1. Shocking!-rinehart-dyno.jpg
Old 10-25-2012, 06:39 PM
MichiganRider
Today I had the bike retuned after installing a RB racing Pro Stock spyder 2 into 1 exhaust. Maybe the Duals are not as bad as everyone thinks!
Same dyno, same tuner.
Attached Thumbnails Dyno results with duals to 2-1. Shocking!-rb-racing-dyno.jpg
Old 10-25-2012, 06:40 PM
CSMHOG's Avatar
CSMHOG
CSMHOG is offline
Waiting with baited breath here
Old 10-25-2012, 06:43 PM
CSMHOG's Avatar
CSMHOG
CSMHOG is offline
Interesting results. I'll admit it's not what I expected.
Old 10-25-2012, 06:48 PM
MichiganRider
Don't pay attention to the big dip. Tuner said he let off and hit it again. I know, sounds lame. It was 14* warmer and 26% more humid too.
1 ft lb more torque with the exact same HP. At least the Torque curve looks a little higher throughout most of the rpm range.
Bike runs great! But I thought the numbers would be a little higher, especially down low.
Old 10-25-2012, 06:56 PM
rubberfrog's Avatar
rubberfrog
rubberfrog is offline
You can't compare the results if it was 14 degrees hotter and more humid. That's like racing uphill and then comparing it to your downhill time.
Old 10-25-2012, 07:10 PM
MichiganRider
Doesn't the results adjust for weather? It was only 75 today (high for Oct in Michigan) but maybe it was that high in the dyno cell. That's what the sheets says for both runs.
Old 10-25-2012, 09:15 PM
gsxrboy96's Avatar
gsxrboy96
gsxrboy96 is offline
I'm not the biggest rb fan, but I'm Impressed with the true duals lol
Old 10-25-2012, 09:33 PM
Biggzed's Avatar
Biggzed
Biggzed is offline
Does the AFR trace look as good on the 2-1 sheet as it did on the duals? It got cut off on your scan.
Zach
Old 10-25-2012, 09:53 PM
MichiganRider
Zach
There is a second sheet with the AFR. It looks great.
Quick Reply: Dyno results with duals to 2-1. Shocking!
