Solid engine Mounts?
Old 10-25-2012 | 12:07 AM
sgt. slaughter's Avatar
sgt. slaughter
Default Solid engine Mounts?
Has anyone done solid engine mounting in place of the rubber? I realize the felt vibration will be a bit on the extreme side, but I am OK with that.
I am wondering if the frame will handle the vibration of the 127" combined with a sticky 200 tire, chain final drive and some drag strip use.
I am going to be widening and lengthening the swingarm and would like to eliminate all the rubber in the swingarm mount, and if I rigid mount the rear trans mount, I would have to solid mount the other points as well.
Old 10-25-2012 | 06:07 AM
grbrown's Avatar
grbrown
I don't see any benefit in doing that. If you take a close look at your bike you will see that the front rubber mount has a lateral stabilizer and there is also one between the heads. To improve driveline stability simply fit a rear stabiliser from True-Track and be done! It will take you an hour or so to install and it will transform things, and achieve what you want to handle your 127". Simples!
mang0
08-03-2016 12:26 PM
newdyna
01-20-2016 11:22 AM
ftwflh
05-01-2015 09:17 PM
jermil32
Ironhead
09-12-2007 12:57 PM
magna3500hd
01-07-2007 09:21 AM
